Hondata s100 help
Old Aug 12, 2003 | 05:39 PM
B18Flip's Avatar
Default Hondata s100 help
I got my hondata s100b and p28 socketed a while ago and tried to start the car with it today with no luck. The car won't start and when the was no light on the s100 unit. Has anyone run into this problem?
Old Aug 12, 2003 | 06:13 PM
ekb18c's Avatar
Default Re: Hondata s100 help (B18Flip)
Do you have a start up map loaded on the chip? Wait, do you even have a chip in the p28? the s100 led should be lite up.
Old Aug 12, 2003 | 06:36 PM
B18Flip's Avatar
Default Re: Hondata s100 help (ekb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a start up map loaded on the chip? Wait, do you even have a chip in the p28? the s100 led should be lite up. </TD></TR></TABLE>
not sure if i got a start up map but i did get a base map from kyle for my setup...is that the same thing? And the p28 was socketed and chipped with the chip that came with the s100 at nrgtech.
Old Aug 12, 2003 | 06:38 PM
Foozball26's Avatar
What is happening that won't make it start?
Sounds like you are just not getting any power to the unit. Check the wiring.
Old Aug 12, 2003 | 06:39 PM
B18Flip's Avatar
Default Re: Hondata s100 help (Foozball26)
yup i made sure all the wiring was ok. the harness was from blown90hatch and i'm pretty sure his work is good. The stock harness was fine because it started up with the stock ecu...i hope my ecu is ok and that its something minor ( crosses fingers)
Old Aug 13, 2003 | 08:24 AM
B18Flip's Avatar
up for lunch
Old Aug 13, 2003 | 08:37 AM
Spunkster's Avatar
I would recommend taking it to your tuner to have them see what is going on. They can hook up their s200 and go from there.
Old Aug 17, 2003 | 10:11 AM
B18Flip's Avatar
Default Re: Hondata s100 help (Spunkster)
Thanks for the help guys, tom at nrgtech gave me a tip and it worked....is the red led supposed to blink or stay steady?
Old Aug 17, 2003 | 10:59 AM
Spunkster's Avatar
steady
boondocks1805
Engine Management and Tuning
Sep 7, 2008 07:00 PM
coolhandluke
Jun 6, 2008 07:16 AM
tgreene2098
May 14, 2008 03:09 PM
CRX RACER
Mar 29, 2005 10:41 AM
