need help with rebuilding turbo!!!
Honda-Tech Double Platinum Member
Well my seals are gone on my turbo so i need to get it rebuilt. Who should i send it to to get it rebuilt? And most importantly...how much is this gonna cost me? Its a t3/t4 and it came with a kit that i bought from thepartstrader.com. Thanks
Sean
Sean
Re: need help with rebuilding turbo!!! (sCeRaXn)
check this out https://honda-tech.com/zerothread?id=578940 this is when he did mine.just the seals were bad,went thru the whole thing and balanced the turbo too.$250,1 day turn around.
Re: need help with rebuilding turbo!!! (pickup1)
I got mine rebuilt through cheapturbo.com. I thought that they did an excellent job. Check them out. if you want to talk to someone about it you can call or check if they are online. they have an AIM address "CHEAPTURBO".
Re: need help with rebuilding turbo!!! (T-sohctec)
get the kit yourself, when u take the turbine shaft out mark the shaft and cold turbine, so it keeps itself balanced.
waspcrx19
05-05-2010 09:40 AM
