engine lift spots
Old Aug 11, 2003 | 04:49 PM
civickiller's Avatar
Default engine lift spots
k i wanna lift my engine out, just the engine not the engine and tranny, and i wanan know where the lift points are on just the engine not tranny.
and its an ls motor too
Old Aug 11, 2003 | 07:37 PM
Default Re: engine lift spots (civickiller)
bump
Old Aug 11, 2003 | 07:53 PM
TomO's Avatar
usually I will pull the drivers side mount and then place one chain on the stud and hold it on with a nut, and then use one bolt from the passenger side tranny mount, but since you aren't pulling the tranny with the engine....ya might want to use one of the transmission bolts in the block where the tranny would normally bolt up to. that should do it for ya.
Old Aug 11, 2003 | 09:02 PM
Default Re: engine lift spots (SonicGSR98)
i would use a tranny bolt but i cant use the tranny bolt without first lifting up the engine so i can get the botl to clear the tranny. i cant lift the engine up to even clear the tranny so i cant use one of thsoe bolts but thanks anyways
Old Aug 11, 2003 | 09:28 PM
sporkcrx's Avatar
Just take out the tranny and engine together, it's much easier.
Old Aug 11, 2003 | 09:38 PM
FourthGenHatch's Avatar
Default Re: engine lift spots (sporkcrx)
Much easier to take them out together.
I used a tranny mount bolt stuck in one of the threaded spots on the front, and then the starter bolt for the other side and attached the chain to those.
Old Aug 12, 2003 | 03:58 AM
Default Re: engine lift spots (FourthGenHatch)
its hard getting it out with my ac lines in there plus i gotta take off my axles and everything. i mean its like if i could find engine spots i would just take out the engine but now i see its hard so ill just take the whole thing out
thanks to everyone who replied
Old Aug 12, 2003 | 07:28 AM
silverkorn's Avatar
you could always drop the engine out of the car. but thats really if you have acces to a car hoist.
Old Aug 12, 2003 | 08:06 AM
keithv's Avatar
Default Re: (silverkorn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverkorn &raquo;</TD></TR><TR><TD CLASS="quote">you could always drop the engine out of the car. but thats really if you have acces to a car hoist.</TD></TR></TABLE>
car hoist??? naahhhhh....
https://honda-tech.com/zerothread?id=411175
Old Aug 12, 2003 | 10:01 AM
RCautoworks's Avatar
Default Re: (keithv)
I usually wrap the chain around the engine a couple times. Wrapping around helps because then the engine won't dip on one side. I found out if you use the lifting points on the engine, when your lowering it the tranny side will lean farther down then the engine and it makes it harder lining up the mounts.
Old Aug 12, 2003 | 12:44 PM
Default Re: (90blackcrx)
well i decided on just taking the whoel tranny and engine out together.
and i need my tranny lower than my engine so i can clear the ac lines
integraGSR213
Feb 16, 2004 11:19 AM
spladam02
Dec 8, 2002 06:42 PM
GruvyTune
Jul 1, 2002 09:02 PM
Turbohatch
Oct 26, 2001 12:25 PM
AshlandSi
Oct 15, 2001 06:55 PM
