manual ecu question
I have a 99 ej6. I did an auto to manual swap and now I'm throwing some codes from my ecu being an auto. I've tried to look for a manual ecu that will fit but none will. I have a non-vtec engine, and 4 sockets in my original ecu. Most of the manual ecu's I've come across have 3 sockets. Am I ever going to find one that will work? Do all manual ecu's have 3 sockets??
Modified by Jswpstdoff at 3:13 PM 8/13/2003
Yes all manual ecu's are 3 sockets the 4th plug you dont use as they are for the auto sensors etc on the auto tranny. If you want change your harness to a manual harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff »</TD></TR><TR><TD CLASS="quote">can I use the auto harness with the manual ecu? I don't think so, just asking.........</TD></TR></TABLE>
its quite possible that the 4th plug on the auto harness is all autotranny wires
I have a manual ecu and tried to hook it up but the car wouldn't start with the fourth plug out. Should it have started?? Did I do something wrong??
Modified by Jswpstdoff at 8:38 PM 8/11/2003
Never heard of that before, "set the jumper", but if you got a "how-to" or can give me some steps, I'd appreciate it a lot. Anyone else know how either??
ah damn, you got an OBDII v2 ECU
thought you had like obd1 or so..
the obdII have 4 plugs in the back
Everyone else is thinking about obd1, which i thought too. Which as 3 plug:
On the obd1 ecu, their's a little 20 pin chip that makes it Auto
See if you had that obd1 auto ecu, you can remove that chip, and it will become a manual tranny ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">I have one from my 00 HX that might work for you but without vtec you might throw a couple codes</TD></TR></TABLE>
yes without vtec, I will throw at least three codes
oh yea. if you have an auto/man swap, then u need to do some in car wiring to fool the manual ECU. u need to wire or jump the clutch safety switch, and a bunch of other stuff
Modified by dantastic at 10:38 PM 8/12/2003
Why dont u just buy a 99-00 DX 5 speed ECU thats what i did, im runing a auto DX ecu and im planing to swap to 5 speed, im going to just buy a 99-00 DX 5 speed ecu, they are cheap like 40 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">Why dont u just buy a 99-00 DX 5 speed ECU thats what i did, im runing a auto DX ecu and im planing to swap to 5 speed, im going to just buy a 99-00 DX 5 speed ecu, they are cheap like 40 bucks.</TD></TR></TABLE>
for some reason it doesn't work, maybe I wasn't sold a 99-00 dx ecu
first you are saying that's what you did, then you're saying you're just going to buy one, and you plan on swapping, have you done it? are you speaking from experience or not??
Did the DX ecu work with the auto engine harness?? Or did he have to swap to the manual engine harness with the manual ecu??
Please help, you're giving me hope!!!!!
tealsvteceg
May 25, 2008 04:18 PM
turboex
Apr 12, 2002 10:43 PM
