Where are all the stock grounds?
Old Aug 9, 2003 | 10:43 AM
B2FiNiTY's Avatar
Default Where are all the stock grounds?
Other than the obvious valve cover ground where are all the other ground wires? I want to check them and possibly replace them.
Old Aug 9, 2003 | 12:00 PM
fourthgenhatchB17's Avatar
tranny to frame, battery to frame...
BTW, u get that timing thing figured out?
Old Aug 9, 2003 | 12:10 PM
B2FiNiTY's Avatar
Only 2. Easy. Thanks.
You have IM too.
Old Aug 9, 2003 | 01:28 PM
SiR Kid's Avatar
New User
Default Re: (B2FiNiTY)
There's one on the waterneck in the harness, too.
Old Aug 9, 2003 | 02:03 PM
B2FiNiTY's Avatar
Default Re: (SiR Kid)
What's the water neck?
Old Aug 9, 2003 | 02:08 PM
.Noah Fecks's Avatar
i think hes refering to the radiator filler neck. but theres not one there
Old Aug 9, 2003 | 02:49 PM
FourthGenHatch's Avatar
Default Re:
There are 3...
Valve Cover > Chassis
Negative Battery Post > Chassis > Transmission
Thermostat > Wire harness
Old Aug 9, 2003 | 02:58 PM
Hcivic88's Avatar
Default Re: Re: (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">There are 3...
Valve Cover &gt; Chassis
Negative Battery Post &gt; Chassis &gt; Transmission
Thermostat &gt; Wire harness</TD></TR></TABLE>
the battery to chassis to transmission is one wire, like fourthgenhatch said, they're not 2 seperate wires. If you're going to be replacing the grounds, i'd suggest using a slightly heavier wire.
Old Aug 9, 2003 | 04:30 PM
B2FiNiTY's Avatar
Default Re: Re: (Hcivic88)
Thanks guy!
Old Aug 10, 2003 | 12:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic88 &raquo;</TD></TR><TR><TD CLASS="quote">
the battery to chassis to transmission is one wire, like fourthgenhatch said, they're not 2 seperate wires. If you're going to be replacing the grounds, i'd suggest using a slightly heavier wire.</TD></TR></TABLE>
On an ALL original car the ground from the battery to frame to tranny is a one wire deal. On my car, and some other peoples, they have been replaced with aftermarket ones long ago and are now two separate wires. B2finity is talking about replacing them and unless he goes to HONDA, hes not gonna get the one ground wire deal from Kragen or Autozone. About the thermostat housing ground, u cant replace that one unless u open up the entire wiring loom and replace the entire wire....but of course thats WAY too much work and not even worth doing. For that ground, just make sure the surface (where the ground wire bolts on) on the thermo. housing is nice and clean so it provides a good ground.
Old Aug 10, 2003 | 01:48 PM
B2FiNiTY's Avatar
Default Re: Re: (fourthgenhatchB17)
I'm planning on doing a grounding kit and while I'm at it, I will just upgrade most of the stock gounds.
Old Aug 10, 2003 | 04:20 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Re: (B2FiNiTY)
i made my own ground kit from this amp wiring pack from Wal Mart. It was in the car stereo section and cost less than 20 bucks. It had an assortment different gauge wires and had a selection of ring clamps in it also. Pretty good deal and left me with lots of extra wires if i ever need them in the future.
Old Aug 10, 2003 | 05:04 PM
Hcivic88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">
B2finity is talking about replacing them and unless he goes to HONDA, hes not gonna get the one ground wire deal from Kragen or Autozone. </TD></TR></TABLE>
I didnt go to honda and was able to get the 1 wire that will go from the battery -&gt; chassis -&gt; transmission. I found one with the bracket and everything, it was just a universal fit, so theres a bit more slack in it now, but its not even noticible at all. If they wouldnt have had the one wire, i would have just used two, but since they had it, why not.
Old Aug 11, 2003 | 11:37 AM
I didnt go to honda and was able to get the 1 wire that will go from the battery -&gt; chassis -&gt; transmission. I found one with the bracket and everything, it was just a universal fit, so theres a bit more slack in it now, but its not even noticible at all. If they wouldnt have had the one wire, i would have just used two, but since they had it, why not.</TD></TR></TABLE>
Never seen them...where would i go to get it?
Old Aug 11, 2003 | 01:53 PM
Hcivic88's Avatar
Never seen them...where would i go to get it?</TD></TR></TABLE>
I got mine at a "carquest" store if that helps at all. I didnt look around anywhere else though, since that was the first place i went, so i didnt have to look any more.
Old Oct 27, 2003 | 03:52 PM
crxaddikt's Avatar
i got one at autozone, it had a thick wire guage and went from negative terminal to body ground, to tranny ground, but the middle part that grounds to the body did'nt go low enough so i had to ground it on the top metal above the headlight.
Razr2
Oct 15, 2008 06:31 AM
obuhmyuh
13
Feb 11, 2008 05:44 PM
yeedub
Dec 10, 2006 12:53 PM
MadCityLude
Aug 23, 2006 10:11 PM
wannab20hatch
Oct 12, 2002 10:15 AM
