i need help! ( timing belt tdc) problem
Old Aug 8, 2003 | 04:47 PM
flip b18b's Avatar
Default i need help! ( timing belt tdc) problem
i am currently atempting to reinstall my timing belt on my d16z6 and i can't figure out what tdc is from the marks on the stock cam gear, there is up a line then another i just tryed with up at tdc and the car would not start
Old Aug 8, 2003 | 04:49 PM
SuperMan19's Avatar
New User
Default Re: i need help! ( timing belt tdc) problem (flip b18b)
there's also a mark on the crank pulley too, you have to get that lined up right too.
Old Aug 8, 2003 | 04:50 PM
flip b18b's Avatar
Default Re: i need help! (SuperMan19)
i was wondering if the up on the cam gear is the correct marking to line up with on the crank pully
Modified by flip b18b at 10:20 PM 8/8/2003
Old Aug 8, 2003 | 05:23 PM
flip b18b's Avatar
please help what lines do i go off from the crank pully i'm stumped at y my car won't run
Old Aug 8, 2003 | 06:21 PM
flip b18b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperMan19 &raquo;</TD></TR><TR><TD CLASS="quote">there's also a mark on the crank pulley too, you have to get that lined up right too.</TD></TR></TABLE> witch mark on the crank pully is that there apears to be 2 , one with 2 lines then a singluar line thanks for any help i'm currently trying to get this car to run
Old Aug 8, 2003 | 06:49 PM
Luserkid's Avatar
Default Re: i need help! (flip b18b)
I had that same prob but mine was for my DOHC so its a lil more of a bitch. But heres my thread i hope this helps you
https://honda-tech.com/zerothread?id=458200
Old Aug 8, 2003 | 07:05 PM
92hatchdude's Avatar
I am currently putting my z6 back together after a blown head gasket. I talked to a guy on here about how to make sure you have TDC. Here is what i have done. Granted, I am about a day away from crankiing mine up, but I am pretty confident this method will work with maybe a minor timing adjustment.
First of all there is a mark on the rear timing cover that allows you to set your cam correctly. On the rear cover that sits behind the timing gear look to the bottom left and there is a little mark. Rotate the cam gear till its in the "up position and line the little line engraved into the gear at the bottom left with the mark on the rear timing cover on the bottom left. Your cam is now set.
Now for the crank, the easiest way to get TDC is to put a long screwdriver or other object in the #1 cylinder and turn the crank. When #1 piston reaches its highest point you should be at TDC. Also, the keyway on the crank should be pretty close to top center.
Also, before you attempt to crank up your engine, rotate the crank with the belt installed a few times to make sure your valves wont hit pistons.
Hopefully this is all correct, maybe some of the other guys on here can add to or correct me!
Old Aug 9, 2003 | 08:14 AM
Luserkid's Avatar
Default Re: i need help! (92hatchdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchdude &raquo;</TD></TR><TR><TD CLASS="quote">Now for the crank, the easiest way to get TDC is to put a long screwdriver or other object in the #1 cylinder and turn the crank. When #1 piston reaches its highest point you should be at TDC. Also, the keyway on the crank should be pretty close to top center.
Damn i never thought of doing that. I bet it would have saved me alot of problems, but now im use to finding it off the crank now. Free bump for more help.
Old Aug 9, 2003 | 07:31 PM
crx304's Avatar
Default Re: i need help! (Luserkid)
good job 92hatchdude!!!!
lookie here... https://honda-tech.com/zerothread?id=587381
mike
Old Aug 10, 2003 | 11:41 PM
david90's Avatar
[Now for the crank, the easiest way to get TDC is to put a long screwdriver or other object in the #1 cylinder and turn the crank. When #1 piston reaches its highest point you should be at TDC. Also, the keyway on the crank should be pretty close to top center.]
the engine goes tdc two times. I think u should take off distrubutor and watch for the rotor to rotate to the 1st spark plug. If u just watch the screwdriver go up and down, u might be 180 degrees off tdc and that won't be good
Old Aug 10, 2003 | 11:45 PM
Kamin's Avatar
Default Re: i need help! (david90)
Um you guys know there is a mark on the timing belt gear and the oil pump that designates TDC right? there is also a mark on the crank pulley and lower timing belt cover that will match with TDC
i would NOT stick something in the cylinder.
Old Aug 11, 2003 | 03:53 AM
Default Re: i need help! (Kamin)
Well it worked for me..mine cranked up on the first turn of the key and the timing was perfect, valve clearance was good. everything was cool. As long as you are careful, I dont see how looking at marks on the crank is anymore accurate than actually seeing exactly where the piston reaches TDC. Just my 2 cents..
Old Aug 11, 2003 | 10:50 AM
david90's Avatar
where does "just my 2 cents" come from?
Old Aug 11, 2003 | 11:18 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchdude &raquo;</TD></TR><TR><TD CLASS="quote">Well it worked for me..mine cranked up on the first turn of the key and the timing was perfect, valve clearance was good. everything was cool. As long as you are careful, I dont see how looking at marks on the crank is anymore accurate than actually seeing exactly where the piston reaches TDC. Just my 2 cents.. </TD></TR></TABLE>
lol dude you are missing the point
you are shoving something in the cylinder
what happens if you score the cylinder wall? what about the threads on the head for the spark plug?
there are marks all over the crank pulley oil pump timing belt cear and lower tbelt cover for a reason. sure the screwdriver thing works, but i would never do it.
foolsforever
11
Aug 9, 2018 05:08 PM
wambus
Honda Civic (2001 - 2005)
Feb 22, 2010 08:05 PM
JRciv
Nov 22, 2004 01:58 PM
spyderracing
14
Sep 26, 2004 09:10 AM
OnebadJdmEg6
Aug 7, 2003 09:24 PM
