99 Si - CA smog - I/H/E?
Old Aug 8, 2003 | 09:41 AM
crazy eyez killa
Guest
Posts: n/a
Default 99 Si - CA smog - I/H/E?
Will my 99 Si pass CA smog check with AEM CAI, DC 4-1 USDM, and a GReddy 60mm EVO exhaust? As long as my cat is in working condition?
Or should I take the header off for good measure?
Old Aug 8, 2003 | 09:43 AM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: 99 Si - CA smog - I/H/E? (CivicCLMT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicCLMT &raquo;</TD></TR><TR><TD CLASS="quote">Will my 99 Si pass CA smog check with AEM CAI, DC 4-1 USDM, and a GReddy 60mm EVO exhaust? As long as my cat is in working condition?
</TD></TR></TABLE>it should pass all of those have carb number que no?? if i were you i would take it off anyways just to be sure...they arent taht hard to remove and install again
Old Aug 8, 2003 | 09:50 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: 99 Si - CA smog - I/H/E? (ciRcuitSi y0!)
Intake and HEADER have CARB numbers but I don't think anyone put CARB #'s on exhausts.
Modified by CivicCLMT at 11:00 AM 8/8/2003
Old Aug 8, 2003 | 09:56 AM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicCLMT &raquo;</TD></TR><TR><TD CLASS="quote">Intake and exhaust have CARB numbers but I don't think anyone put CARB #'s on exhausts.
correct exhaust... after the cat in no way modify emmisions thus no carb number.
u should pass visual since u have all the carb numbers.
id recommend driving your car awhile to get the cat hot... ceramic coated headers shed heat and may not get your cat hot enough to do its job well enough.
gl
Old Aug 8, 2003 | 10:00 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: 99 Si - CA smog - I/H/E? (psileepR)
The sentence taht u quoted was written funny so I fixed it
Old Aug 8, 2003 | 10:01 AM
rodrez.'s Avatar
I passed my swap at the ref with I/H/E. As long as the cat is good, and the motor is tuned up, should be ok.
Old Aug 8, 2003 | 10:04 AM
Broken Gearbox's Avatar
Default Re: 99 Si - CA smog - I/H/E? (rodrez)
yea...you should pass.
Old Aug 8, 2003 | 10:28 AM
Luigi's Avatar
Default Re: 99 Si - CA smog - I/H/E? (James.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James. &raquo;</TD></TR><TR><TD CLASS="quote">yea...you should pass. </TD></TR></TABLE>
Yep
Old Aug 8, 2003 | 11:30 AM
acuracing's Avatar
The smog test should be a piece of cake.
Old Aug 8, 2003 | 12:09 PM
cleanEG's Avatar
Default Re: 99 Si - CA smog - I/H/E? (acuracing)
Take my advice....remove the Header and put on the stock manifold. Reason being is that the DC header does not heat up the exhaust enough for the Catalytic to work properly. On my GSR before rebuilding it...I took 3 times at the "test only" station to pass and after changing the cat, valve job, new plugs, new cap/rotor, adjusting fuel pressure...it finally passed after changing out the header. So save yourself some time/money and spend an hour at home changing the header.
Old Aug 10, 2003 | 11:27 AM
Viorent GRIP!'s Avatar
just do burnouts down the road
Old Aug 10, 2003 | 11:28 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: 99 Si - CA smog - I/H/E? (Viorent GRIP!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Viorent GRIP! &raquo;</TD></TR><TR><TD CLASS="quote">just do burnouts down the road</TD></TR></TABLE>
lol
hahah
Imp-tuner
Dec 10, 2007 11:58 AM
aquito
Sep 26, 2006 08:43 PM
Delano5050
14
Sep 1, 2006 08:40 PM
SIguy626
16
Jul 19, 2006 01:59 PM
SD_EM1
Sep 6, 2003 10:47 AM
