Vac leak from injector seals?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOFLSOL »</TD></TR><TR><TD CLASS="quote">Ok. Because I remember hearing it makes you hit off the rev limiter when you start up heh.</TD></TR></TABLE>
That's pretty much true of any vacuum leak so long as it's big enough. For something that big.. I'd check to make sure you used a throttle body gasket
GetawayInMoscow
Nov 21, 2006 07:57 AM
