figured out what is keeping me from getting oil sending unit off pic inside
Old Aug 7, 2003 | 08:42 PM
Nextelbuddy's Avatar
Default figured out what is keeping me from getting oil sending unit off pic inside
ok i found out from c-speed racing site what is blocking my socket from fitting over the oil pressure sending unit on the back of my b18c1.. it appears that my b18c1 has an oil cooler that has a metal tube on it that is right near my oil sending unit. heres a pic to show u what im talkin about. i have never seen this on my type r motor or my b16 motor that is why i was baffled when i saw it on here. i was wondering if theres other people that had this same problem when trying to get their oil pressure sending unit off.. i am open to suggestions....
Old Aug 8, 2003 | 05:05 AM
Default Re: figured out what is keeping me from getting oil sending unit off pic inside (nextelbuddy)
bump
Old Aug 8, 2003 | 06:42 AM
so no one here has had any experience with this part on their b18c1 motors or had any problems with it prohibiting u from getting the oil pressure sending unit off what so ever?? i find that hard to beleive
Old Aug 8, 2003 | 06:48 AM
MachAF's Avatar
nope. oil cooler on mine. 24mm deep socket took of the sending unit for me.
Old Aug 8, 2003 | 06:55 AM
Default Re: figured out what is keeping me from getting oil sending unit off pic inside (MachAF)
is it possible that that oil cooler can be loosened up and turned slightly so that the metal tube that is attached top it is moved away form teh sending unit? because it appears that the person that owned this motor before moved it or something. i was just wondering becasue on c-speeds site they showed them being able to remove it by loosing the main nut in the middle after u remove the oil filter so instead of removing it is it possible to just loosen it up and turn it slightly and then tighten it back down if i can then that will clear up a lot of room for me...
Old Aug 8, 2003 | 07:07 AM
Bailhatch's Avatar
ya what that guy said. cut one of the tabs off that allignmet thingy and turn it slightly.
Old Aug 8, 2003 | 07:11 AM
Default Re: figured out what is keeping me from getting oil sending unit off pic inside (Bailhatch)
what are u talkin abotu no one said anything about cutting any tabs off. i said in a post earlier something about turning the assembly if thats possible... any one know?
Old Aug 8, 2003 | 08:37 AM
FuzzyGreen's Avatar
I had no problems getting the oil pressure sender out with the oil cooler in place. I just used a deep socket. B21 engine tho...
Old Aug 8, 2003 | 08:55 AM
Farnsrocket's Avatar
Default Re: (FuzzyGreenCarpets)
Hmmmm, not sure how that is blocking your sending unit. Here is a pic of my B18c1 and those metal lines are nowhere close to my sending unit. They must have rotated the cooler on your motor alot. Mine is mounted the way it should be with the metal lines pretty much at the 12 o'clock position.
Old Aug 8, 2003 | 09:10 AM
Default Re: (Farnsrocket)
YES!!!!! thank you soo much finalyl some one understands what im talkin abot. on my blockthat oil line that is at about 12:00 oln your block on my block its at about 9:00 and i can not get my socket around the sender unit because that line is almost touching the sending unit.. what i want to know is if its possible to rotate the oil cooler back to 12:00? and if its possible how do i do it?? thaks so much u understand what im talkin about.
Old Aug 8, 2003 | 10:03 AM
wambus's Avatar
Default rotating the oil cooler connection
As someone posted, there may be an alignment tab on the back that determines the way the unit sits. The unit on my son's civic has no tab and the lines come straight off (perpendicular) the block - we used remote filter location. You should be able to loosen or remove the center bolt and rotate or remove the whole plate as necessary.
NOW - someone please help me. My son is trying to remove the sending unit. He says he can't get the rubber cover off of it. I am at work so I can't have a look at it. Is there a trick to this?
Thanks,
Doug
Old Aug 8, 2003 | 10:17 AM
Default Re: rotating the oil cooler connection (wambus)
i used a long small tip flat head screw driveer to lift the boot off the sending unit. also a set of long needle nose pliars will work too.
Old Aug 8, 2003 | 10:34 AM
Default Re: rotating the oil cooler connection (nextelbuddy)
does any one know what size socket or wrench i use to get the center bolt off that holds the oil cooler on ?
Old Aug 8, 2003 | 02:55 PM
I wanna say a 23 or 24mm........I would have to go check.
Boosted2K
Jul 10, 2006 09:47 AM
RacingShoeBox
Mar 26, 2006 07:37 AM
RemerLex11
May 15, 2005 02:35 PM
90crxzc
Dec 6, 2003 01:36 PM
