I hate the TPS! anyone have a "how to adjust"
Old Aug 6, 2003 | 08:42 PM
manson's Avatar
Default I hate the TPS! anyone have a "how to adjust"
i have seached but im unsure as how to adjust the tps sensor. this really sucks because when the engine light comes up i lose vtec. i need my vtec!
so if anyone has a how to adjust guide it would be most appriciated. what kind of tools do i need as well. im just lost when it comes to sensors. is the tps bypassable? just curious.
thanks much
Old Aug 6, 2003 | 08:45 PM
4crx4me's Avatar
Default Re: I hate the TPS! anyone have a "how to adjust" (mansonclubpuir)
You need a volt meter and a Helm manual would help.
Voltage should be at .5v at closed throttle and I think 5.v at full throttle. I'll check my helms though. When it's within spec tighten down with allen screws.
Old Aug 6, 2003 | 09:40 PM
ZetecOwns's Avatar
Default Re: I hate the TPS! anyone have a "how to adjust" (4crx4me)
TPS? Did you get the memo?
Old Aug 6, 2003 | 09:52 PM
raene's Avatar
It sounds wonderfully easy on paper, but in practice, using a voltmeter/multimeter - especially a cheapa$$ one like from the local Crappy Tire - is just not going to work. It's completely inaccurate over such a broad range.
I haven't really figured out how to adjust the TPS while taking into account the inaccurate voltmeters yet I'm trying to get mine adjusted right also (currently the voltmeter says 0.3V closed, 4V at WOT, adjust it higher and the engine races on idle and during deceleration).
I figure the best thing to do would be to use Hondata S200 with datalogging option or at least digital dash and adjust the TPS based on the volts the ECU is seeing. But that's impractical due to expenses
Old Aug 7, 2003 | 07:37 AM
manson's Avatar
Default Re: I hate the TPS! anyone have a "how to adjust" (raene)
well it doesn't sound too easy, guess i'll go to he shop and try to adjust it today.
thanks for the help....
if anyone has a helms and they can look up the exact spec volts for the tps please post them.
THANKS!
Old Aug 7, 2003 | 07:57 AM
4crx4me's Avatar
Fully closed throttle, appx 0.5v (with vacuum applied to dashpot.)
fully open throttle 4.5v no vacuum applied.
there sholud be a smooth transition from from 0.5 to 4.5v as throttle is opened to wide open position.
HTH
Old Aug 7, 2003 | 08:17 AM
raene's Avatar
That is correct... Hondata can tell you how to adjust the TPS correctly
I just can't do it right, that's all
Old Aug 7, 2003 | 11:37 AM
xci_ed6's Avatar
I got mine on the first try I'm lucky. I used a craftsman DVOM.
-Dustin
Old Aug 7, 2003 | 02:33 PM
manson's Avatar
Default Re: I hate the TPS! anyone have a "how to adjust" (krustindumm)
well its going to the shop tomarrow for some brake work anyways so i'll have them look at it while im there. i could do it, but why not just have my gear heads do it while they have it ya know. thanks for all the input.
Old Aug 8, 2003 | 06:39 AM
Xsi's Avatar
Xsi
I hate it too! putting it at 0.5V and 0.45V as some people say didn't help my idle problems so now I have mine set at 0.32V which seems to be better.
DCxMagus
May 3, 2007 06:45 AM
JDMSirEK4
Aug 26, 2005 05:48 AM
gamakichi77
Feb 24, 2004 05:17 PM
ophdehEEzY
May 16, 2003 08:25 PM
evo
Apr 9, 2002 09:39 PM
