Which ECU to use for my B16A2?
Old Aug 6, 2003 | 10:51 AM
poktan's Avatar
Default Which ECU to use for my B16A2?
Wassup guys...I just recently got a B16A2 swap done off of a 99 SI. I have 2 ECUs right now...USDM P73 (ITR) and a JDM PCT (CTR). To all the ECU experts out there, which one should I go with?
Whichever one I don't use I think I'll sell.
Thanks
Old Aug 6, 2003 | 01:00 PM
Prevail's Avatar
Default Re: Which ECU to use for my B16A2? (poktan)
I think you should sell them and get a 99 SI ECU, since your maps/vtec crossover will be programmed to produce less power with that engine, since its not the right engine. I think the ITR ecu's run rich also, which would just make you run even richer.
99 SI ECU
Old Aug 6, 2003 | 01:02 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Which ECU to use for my B16A2? (civicscantdrift)
depends on which car it is goin in. it is more work to make the 99 si ecu fot a 96-98 car.
Old Aug 6, 2003 | 02:33 PM
poktan's Avatar
Default Re: Which ECU to use for my B16A2? (boostedcivicsir)
Yeah...that's the prob. The swap went into my 97 EK. I have the SI ecu but I'm gonna have to dish out over $200 for an ecu jumper adapter. I think you're right about the richness as I'm not getting expected gas mileage.
But until I get the jumper, the question stands.
P73 or PCT? I noticed VTEC kicks in later for the CTR (~6200rpm), whereas ITR kicks in at around 5800rpm.
salvagetitlesil
Mar 29, 2012 07:15 AM
Break4Gold
Dec 13, 2007 08:44 PM
iRIDEdumped
32
Apr 25, 2005 06:34 PM
IWearMyKswiss
Oct 22, 2003 10:51 PM
Nameless RB26
Aug 27, 2002 05:07 PM
