compatible ECUs for LSvtec
Old 10-22-2003, 10:29 PM
New User
IWearMyKswiss's Avatar
Default compatible ECUs for LSvtec
i know i can use a chipped p28,..but what other ECUs will work with the LSvtec setup,...would a 99 SI ecu work?
Old 10-22-2003, 10:30 PM
Risky Business
BauleyCivic's Avatar
Default Re: compatible ECUs for LSvtec (WiDeBoDyEK)
are you doing OBD-II or OBD-I?
My friend has OBD-II LSVTEC and switches between a P73 ITR ECU and a P2T 99 Si ECU...the ITR ECU has a permanent check engine light because the immobilizer had to be removed when it was taken out of the original car.
Old 10-22-2003, 10:33 PM
New User
Default Re: compatible ECUs for LSvtec (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">are you doing OBD-II or OBD-I?
My friend has OBD-II LSVTEC and switches between a P73 ITR ECU and a P2T 99 Si ECU...the ITR ECU has a permanent check engine light because the immobilizer had to be removed when it was taken out of the original car.</TD></TR></TABLE>
the LSvtec motor is not mine,..im asking for a friend because with my old LSvtec motor,..i used a chipped p28,...he has a 99 LS motor with a 99 SI head (so in other words OBD-II ),..he just asked me if he could use his 99 SI ecu,...so just to clarify,..you are saying YES he can use his 99 SI ecu?
Old 10-22-2003, 10:45 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiDeBoDyEK &raquo;</TD></TR><TR><TD CLASS="quote">
he just asked me if he could use his 99 SI ecu,...so just to clarify,..you are saying YES he can use his 99 SI ecu?</TD></TR></TABLE>
yep
Old 10-22-2003, 10:51 PM
New User
yep </TD></TR></TABLE>
gracias
swoyEKr.
04-13-2006 04:56 PM
AllMoToRB18c
12-09-2003 07:45 AM
poktan
08-06-2003 02:33 PM
underdog
10-03-2001 02:47 PM
Quick Reply: compatible ECUs for LSvtec
