What an ignition upgrade gives you on a turbo car?
Old Aug 6, 2003 | 07:12 AM
Odessa's Avatar
Default What an ignition upgrade gives you on a turbo car?
Hi, I'm trying to figure out if an ignition upgrade is necessary to run a turbo 5 gen lude on stock h22 with about 8-10 psi and EMS and getting around 280-300 whp? Do I need this MSD ignition thing? Coil? Plug wires? Sparkplugs? Well, may be sparkplugs I need...but other ignition related stuff?
Does getting all this stuff adds hp/torque gain, fuel economy, reliability?
Old Aug 6, 2003 | 09:24 AM
squirrel's Avatar
Default Re: What an ignition upgrade gives you on a turbo car? (Odessa)
From what I've heard, I get the impression that OE ignitions that are running "tip top" should be adequatefor low boost.
Aftermarket ignitions are good, and can add power (more efficiency), but are mostly for peace of mind.
Old Aug 7, 2003 | 08:42 AM
Odessa's Avatar
Does anybody else has something to say?
Old Aug 7, 2003 | 08:59 AM
R6Elmo's Avatar
Default Re: (Odessa)
From what i've heard and experienced, the ignition isn't really need until you hit 400+WHP. But as discussed, make sure your current igntion is in good shape, good rotor, d-cap, wires and plugs. Any malfunction here will show up quickly in a FI car.
Old Aug 7, 2003 | 06:53 PM
MooreBoost's Avatar
Default Re: (R6Elmo)
Yup, theyre really not necesary. However its just another one of those things that may give you the edge...
gmoore
Old Aug 7, 2003 | 07:03 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: (tegunderpressure)
for 8-10 psi stock is fine. aftre 15psi and 450whp youll need an ignition system. i like the msd digital 6 or 7 myself.
zexifiedlude
Dec 6, 2005 03:10 AM
shoebox
Jul 28, 2005 09:54 AM
fafsa
Feb 23, 2005 07:39 AM
TurboB18C1
May 8, 2002 09:57 AM
smoothludey2
Jan 7, 2002 08:00 PM
