NEED HELP SOLVING: MISFIRE AT IDLE
Old Aug 5, 2003 | 02:24 PM
ADAH 303's Avatar
Default NEED HELP SOLVING: MISFIRE AT IDLE
RECENTLY REPLACED CAMS, VALVE SPRINGS AND RETAINERS ON A B18B. AFTER START THE ECU REGISTERED A MISFIRE IN CYLINDERS 2, 3 AND 4. CODES 72, 73 AND 74.
WE TOOK DOWN THE TIMING BELT AND PUT BACK UP TO MAKE SURE WE GOT IT RIGHT. WE DID. MISFIRE AT IDLE STILL EXIST. THE MISFIRE IS INTERMITTENT AND ONLY OCCURS AT IDLE. THE CAR RUNS STRONG WITH NO APPARENT MISFIRE AFTER IDLE.
THE MOTOR HAS A NEW EXTERNAL COIL, DISTRIBUTOR CAR, ROTOR AND NEW 8.5MM PLUG WIRES. TRIED DIFFERENT SPARK PLUGS, NO CHANGE.
IDLE CONTROL VALVE OK.
PLEASE HELP
Old Aug 5, 2003 | 02:29 PM
99_SH's Avatar
Default Re: NEED HELP SOLVING: MISFIRE AT IDLE (ADAH 303)
Check your injectors. Put a screwdriver on the injector, and the other end on your ear. Check to hear if they're clicking ok.
Old Aug 6, 2003 | 06:12 AM
ADAH 303's Avatar
Default Re: NEED HELP SOLVING: MISFIRE AT IDLE (99_SH)
ALL INJECTORS OK.
COMPRESSION IN ALL CYLINDERS OK.
ANY OTHER SUGGESTIONS.
Old Aug 6, 2003 | 06:27 AM
Crazydave's Avatar
Does the misfire seem to go away when you rev it up...
or does it just shake more the higher your rev it...
if it seems to get better when you rev it up .. look for vacuum leaks
if it just shakes more when you rev it up
things to check:
make sure you have the firing order correct
make sure all the wires are properly connected.
swap out the old ignition crap for the new ones.
But it it's only happening at idle and not when you rev it up I'd look for leaks..
unconnected hoses, missing gaskets, things like that
Old Aug 6, 2003 | 11:18 AM
Perfectionist's Avatar
FWIW, A quick search on http://www.deja.com in rec.autos.makers.honda yields posts listing causes as being fuel octane rating/type (oxygenated), incorrect spark plugs, crankshaft wobble, plug wires, damp conditions, and a few others.
Old Aug 6, 2003 | 11:49 AM
ADAH 303's Avatar
Default Re: NEED HELP SOLVING: MISFIRE AT IDLE (Crazydave)
THE MISFIRE AT IDLE GOES AWAY AS SOON AS I TOUCH THE ACCELERATOR.
I WILL TAKE YOUR SUGGESTION AND DOUBLE CHECK FOR VACUUM LEAKS.
THANKS DAVE!
ANY OTHER SUGGESTIONS WILL BE APPRECIATED.
Old Aug 6, 2003 | 12:39 PM
g2turbo's Avatar
do a valve adjustment if you havent already. i had that problem before at startup and after a valve adjustment it went away. HTH
Old Aug 7, 2003 | 08:48 AM
Crazydave's Avatar
good luck..
make sure to check for the vacuum hose on the bottom on the throttle body
Old Aug 8, 2003 | 02:37 PM
ADAH 303's Avatar
RE-ADJUSTED VALVES TODAY. IT IS WORKING NO BETTER.
AND NO VACUUM LEAKS FOUND.
THANKS DAVE.
Old Aug 8, 2003 | 03:01 PM
iiilgsrlll's Avatar
Correct me if I'm wrong but if you have a cam profile that is on the wild side you will misfire especially if you are OBD2. I think any cam profile that causes a fluctuation in idle speed will give you a random misfire check light.
Old Aug 8, 2003 | 03:52 PM
non-VTEC's Avatar
Default Re: NEED HELP SOLVING: MISFIRE AT IDLE (iiilgsrlll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if I'm wrong but if you have a cam profile that is on the wild side you will misfire especially if you are OBD2. I think any cam profile that causes a fluctuation in idle speed will give you a random misfire check light. </TD></TR></TABLE>
this man is correct...........all 96+ non-VTEC engines i have come across with aftermarket cams will set misfire codes due to the fact that the engine has a lumpier idle from the radical cam profile.
the engine isn't misfiring. but the ECU thinks it is........this should not affect performance in anyway you just have to live with the annoying check engine light on.
the only fix for it........do a OBD1 conversion...
Old Aug 9, 2003 | 12:13 PM
ADAH 303's Avatar
Default Re: NEED HELP SOLVING: MISFIRE AT IDLE (non-VTEC)
THANK YOU FOR THIS INFORMATION
IT HAS GIVEN ME A LITTLE COMFORT THAT THERE IS NO REAL PROBLEM
BUT I NEED TO KNOW THAT THERE IS NOT SOLUTION WITH MY OBD2 SET UP (1996 RS)
I AM STILL WAITING ON CROWER TO WRITE BACK TO ME.
THANKS YOU GUYS FOR YOUR REPONSE.
MISFIRE AT IDLE.
Old Aug 9, 2003 | 12:23 PM
non-VTEC's Avatar
the only solution is to swap out the OBD2 ECU to a ODB1 ECU.
to do this you need a 94-95 LS non-VTEC ECU and a conversion wire harness.
p.s. welcome to honda-tech......please try not to type in all caplital letters......it's really anoying......have a nice day.
Old Aug 9, 2003 | 08:01 PM
HulkSmash's Avatar
i had the same problem. i converted to obd1. problem solved
Old Aug 10, 2003 | 08:34 PM
ADAH 303's Avatar
Default Re: NEED HELP SOLVING: MISFIRE AT IDLE (HulkSmash)
Can anyone else confirm that they have had this problem with aftermarket cams on 96+ OBD2 non-VTEC Integras?
Thanks for all the information guys!
Old Aug 13, 2003 | 12:21 PM
ADAH 303's Avatar
Can anyone else confirm this problem with aftermarket cams on 1996 Integra RS OBD2 B18B motors?
Any other information?
Thanks.
Old Aug 13, 2003 | 12:57 PM
1_bad_EF's Avatar
almost positive that is what it is. get a obd2 to obd1 conv harness and a reprogrammed ecu meant for those cams and with the appropriate rev limit and fuel curves.
DAb18c
Jul 9, 2011 12:36 PM
thunderlips
Oct 17, 2008 03:19 PM
dointhemzs
Sep 7, 2008 07:09 PM
90crxsib16
Jul 21, 2004 03:51 PM
ArchAngel Sabastian
Sep 11, 2002 09:29 PM
