Help Check engine light!!
I got a check engine light on today after i install the motor mount inserts..It idle real low,and the speedometer(MPH) it doesnt work..please help me out..thanks
i see two blue connector one goes into a green socket..where the vss connector that is on top of the tranny?plmk..thanks
Austin
It should be a small blue connector with 2 wires. Get a paper clip an jump it. Turn the ignition on, but dont start the car, then read the blinking lights.
post your codes and we can tell ya...
Stick one end of the paper clip on one hole of the connector. and the other end of the paper clip on the other hole of the connector. Turn the ignition on, and read the blinking check engine light. Long blinks and short blinks
After youre done counting the lights go here to check the codes http://www.c-speedracing.com/faq/05.html
Each long one counts as 10 and the short ones as they come. Example: blink-pause-blink-pause-blink-pauseblink-blink-blink-long pause, is code 33.
ohk..its not unplug from the green connector..is there another connector somewhere on the motor beside right there in front of the motor?and sould i take it to acura to have them fix it?plmk..thanks
