How to check check engine light code?
Old Feb 19, 2006 | 10:41 AM
01-0720's Avatar
Default How to check check engine light code?
i did a search on check engine light and how to but it only gave me peoples post about i got this code what is and stuff like that
now i remember a while ago there was a post on how to check the codes and a list of what the codes meant
my probelm is i was coming around a badass offramp the other day goin pretty fast and mid turn the check engine light came on
so im not sure, i check my oil and it was a little low so i put somemore in but i dont know what to think
thanks for any help
eric
Old Feb 19, 2006 | 10:44 AM
RTW DC2R's Avatar
Default Re: How to check check engine light code? (01-0720)
http://www.c-speedracing.com/faq/06.php
there is a ton more info in the FAQ of that site as well regarding the codes.
Old Feb 19, 2006 | 10:50 AM
01-0720's Avatar
Default Re: How to check check engine light code? (RTW DC2R)
excellent thank you very much
Old Feb 19, 2006 | 11:02 AM
Haleiwa-Brando's Avatar
It's actually quite simple. On the right hand side of your car...under the dash on the inside and in front of the door there is a little black kick panel. This houses your ECU. You need to remove that then fish around just behind the underside of the dash for a tiny little two wire harness that is blue in color.
You will either need the proper jumper or use a paper clip to pull the codes. So if you use the jumper you plug it in to this blue harness and turn the ignition to the #2 setting then count the check engine light to pull the code(s)
Remember....little blue harness. Two wires. Brown w/ white stripe and 1 silver dot. Solid black with one silver dot.
There is a thread floating around here about resetting your SRS light...in that thread is the part number for the jumper harness.
Old Feb 19, 2006 | 11:05 AM
01-0720's Avatar
ok so im trowing a code 22 which is vtec oil pressure switch defective or unplugged/ defective oil pressure switch
now when i was goin around the turn it felt like the car came out of vtec, and i know when the ecu doesnt see proper oil pressure it will shut of vtec if your in it, now im thinking since i was low on oil and i was hauling *** around the turn all the oil slooshed to one side and lost some oil pressure and the ecu thought the oil pressure switch was busted?? does that sound crazy or what?
thanks
Old Feb 19, 2006 | 11:09 AM
RTW DC2R's Avatar
that sounds about right. fill up on oil, reset the code, and yer good to go.
Old Feb 19, 2006 | 11:11 AM
01-0720's Avatar
Default Re: (RTW DC2R)
good stuff thanks alot again
speed_demon018
Mar 12, 2010 06:47 AM
NewEra
Jul 20, 2009 08:13 PM
nteg4280
Jun 19, 2006 10:04 PM
Slow
Nov 20, 2002 11:11 PM
B_1_8_hatch
Aug 12, 2002 07:41 PM
