Help Check engine light!!
Old Aug 8, 2001 | 04:03 PM
JDM R98's Avatar
Default Help Check engine light!!
I got a check engine light on today after i install the motor mount inserts..It idle real low,and the speedometer(MPH) it doesnt work..please help me out..thanks
Old Aug 8, 2001 | 04:10 PM
BUSAFREAK's Avatar
Default Re: Help Check engine light!! (JDM R98)
What code(s) is it throwing?? Maybe you disconnected something while installing the inserts.
Old Aug 8, 2001 | 04:11 PM
JDM R98's Avatar
Default Re: Help Check engine light!! (ITR1162)
how do i check the code its throwing?
Old Aug 8, 2001 | 04:15 PM
BUSAFREAK's Avatar
Short the blue jumper. Oh wait!! You have a 95 with a 98 motor, so you might not have that jumper. Check though.. Under the right side of the dash
Old Aug 8, 2001 | 04:18 PM
Austin's Avatar
Did you knock your VSS connector loose on top of the transmission?
Old Aug 8, 2001 | 04:25 PM
JDM R98's Avatar
Default Re: Help Check engine light!! (itrAustin)
i see two blue connector one goes into a green socket..where the vss connector that is on top of the tranny?plmk..thanks
Old Aug 8, 2001 | 04:32 PM
Austin's Avatar
Yes, it sitts right on top of your tranny...but the idle problem...?? try to run the codes.
Austin
Old Aug 8, 2001 | 04:33 PM
JDM R98's Avatar
how do you check what code is it throwing?please give me step by step on how to do it
Old Aug 8, 2001 | 04:35 PM
BUSAFREAK's Avatar
It should be a small blue connector with 2 wires. Get a paper clip an jump it. Turn the ignition on, but dont start the car, then read the blinking lights.
post your codes and we can tell ya...
Old Aug 8, 2001 | 04:38 PM
JDM R98's Avatar
how do i jump it
Old Aug 8, 2001 | 04:42 PM
BUSAFREAK's Avatar
Stick one end of the paper clip on one hole of the connector. and the other end of the paper clip on the other hole of the connector. Turn the ignition on, and read the blinking check engine light. Long blinks and short blinks
Old Aug 8, 2001 | 05:05 PM
BUSAFREAK's Avatar
After youre done counting the lights go here to check the codes http://www.c-speedracing.com/faq/05.html
Each long one counts as 10 and the short ones as they come. Example: blink-pause-blink-pause-blink-pauseblink-blink-blink-long pause, is code 33.
Old Aug 8, 2001 | 05:13 PM
JDM R98's Avatar
ohk the code is 22
Old Aug 8, 2001 | 05:19 PM
ITR 01-0907's Avatar
New User
VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure
switch
Old Aug 8, 2001 | 05:28 PM
JDM R98's Avatar
Default Re: Help Check engine light!! (ITR 01-0907)
ohk..its not unplug from the green connector..is there another connector somewhere on the motor beside right there in front of the motor?and sould i take it to acura to have them fix it?plmk..thanks
Old Aug 8, 2001 | 05:40 PM
JDM R98's Avatar
uptop..if so why dont my speedometer dont work also?
ethos0518
Aug 13, 2011 07:36 AM
lowered94accord
Mar 16, 2007 08:27 AM
01-0720
Feb 19, 2006 11:11 AM
Slow
Nov 20, 2002 11:11 PM
HaUTSaauce
Jan 20, 2002 06:00 PM
