Resistor box question... (already searched)
Ok.. after i got everything hooked up... is it ok to hook the rest of the yellow/black wires from the harness to that red wire on the resistor box? or is it possible that I can only just use one? Will there be any electrical problems if i use all of them? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost Type R »</TD></TR><TR><TD CLASS="quote">Ok.. after i got everything hooked up... is it ok to hook the rest of the yellow/black wires from the harness to that red wire on the resistor box? or is it possible that I can only just use one? Will there be any electrical problems if i use all of them? Thanks.</TD></TR></TABLE>
You didn't search enough.
https://honda-tech.com/zerothread?id=517274
Yes, I would wind them all together and solder the 1 red to all of them. That is what I did in my above post.
thanks for the feedback guys.. sorry I dint research enough.. supposedly most people say its possible just to use one.. I was jus checking to make sure.
TYPErCRX
Feb 28, 2005 03:27 AM
