Greddy FCU Question
Old Aug 5, 2003 | 01:18 AM
Secret Squirrel's Avatar
Default Greddy FCU Question
I am in the process of finishing up my turbo project, and have the Greddy blue box completely installed, except for the MAP in and out. If I just go ahead and finish the install, will I be able to drive my car for a week or two before the turbo itself goes in, or should I just hold off on finishing the install.
Old Aug 5, 2003 | 11:53 AM
Default Re: Greddy FCU Question (Secret Squirrel)
Can somebody please give me some info? I am starting to get desperate.
Old Aug 5, 2003 | 12:22 PM
Well I just started the car up with the blue box installed, and it seems to be running fine. The small green LED is blinking, is that what it is supposed to do? Or is is supposed to stay lit?
Old Aug 5, 2003 | 12:36 PM
R6Elmo's Avatar
without the map in and out connected, the blue boxi snt' making any fuel adjustments for your car. You are then basically running off the stock ecu fuel map right? WHy don't you want to connect it? ti's there for a reason.
Old Aug 5, 2003 | 09:26 PM
Pengo's Avatar
blinking is fine. that means its working. having it hooked up should be fine since you're not gonna be getting outta vacuum it's not gonna be doing anything
Old Aug 5, 2003 | 10:42 PM
spooned out's Avatar
yeah when you do hook up your Map signal wire tell me what color it is on your ecu pinout i'm curious.
Old Aug 6, 2003 | 02:56 AM
Default Re: (spooned out)
Alright it is installed, and everything is working fine. As for the MAP on my 00' ex, it was a red and green wire, I believe. Here is a link to the wiring diagrams I used.
http://www.turbod16.com/viewtopic.php?t=625
Boosthead
Jan 5, 2005 07:40 PM
supermac88
Apr 1, 2004 09:40 PM
Quad-Damag
Sep 16, 2003 09:35 AM
VerbalKint
Dec 8, 2002 09:58 PM
greyzone
Nov 16, 2001 07:10 AM
