A b18 AT to MT need help! I AM A NEWBIE
Old Aug 4, 2003 | 09:09 PM
yanasaki's Avatar
Default A b18 AT to MT need help! I AM A NEWBIE
i got a gsr tranny..i want to change my 95 ls auto to manual, should i need to change the axles and the ecu? or i have to change some other parts?
please help, thank you!
Old Aug 4, 2003 | 09:14 PM
CornerCarvingGSR's Avatar
You'll need an ECU from a manual OBD1 LS I believe, probably axl's too. Don't forget the clutch cylinder, pedal assembly, shift linkage, etc. The list goes on and on.
Old Aug 4, 2003 | 09:25 PM
Bspec18's Avatar
Default Re: A b18 AT to MT need help! I AM A NEWBIE (95ls)
Use the search feature, i covered all the parts and other users as well.
Welcome aboard
Old Aug 4, 2003 | 10:57 PM
MR. ARIZONA's Avatar
Default Re: A b18 AT to MT need help! I AM A NEWBIE (Bspec18)
1. Manual Tranny
2. Shifter
3. Shift Linkage
4. Manual ECU
5. Manual Starter
6. Flywheel
7. Hydraulic Lines
8. Clutch (pressure plate)
9. Pedal Assembly
10. Clutch Master Cylindar
11. Slave Cylindar
12. Tach
13. Shift ****
14. Shift Boot
15. Miscallaneous Nuts and Bolts
Old Aug 4, 2003 | 11:57 PM
yanasaki's Avatar
Default Re: A b18 AT to MT need help! I AM A NEWBIE (QUICKTEG)
how about axles?
Old Aug 5, 2003 | 08:53 AM
91tegrals's Avatar
man that sound like a lot of work im glad i baght a stick in the first place..
Old Aug 5, 2003 | 09:42 AM
Default Re: (91tegrals)
Axles are the same I believe.
Old Aug 5, 2003 | 11:51 AM
Xumarius's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ls &raquo;</TD></TR><TR><TD CLASS="quote">i got a gsr tranny..i want to change my 95 ls auto to manual, should i need to change the axles and the ecu? or i have to change some other parts?
please help, thank you!</TD></TR></TABLE>
The best part will be to sell your car and buy a stick GSR
getupoffthatthan
10
Jul 27, 2007 11:11 PM
bman511
Jul 1, 2005 07:04 PM
keoji
Jul 22, 2004 11:29 PM
jspec - integra Ls
May 18, 2004 10:08 PM
Finch8383
Mar 29, 2004 01:37 PM
