need advice on boosted H22 setup
Old Aug 4, 2003 | 08:36 PM
LCDeuce's Avatar
Default need advice on boosted H22 setup
i'm going to turbocharge my bone stock JDM H22A
think i might use a T04E 60trim t3 .63 a/r turbine housing with a stage 5 wheel....or maybe a precision sc61? not sure yet....
anyway, i want to get all the fuel management stuff taken care of before the turbo goes in and was wondering if you guys had any advice.
here's what i'm thinking....
hondata s200 with boost (chipped P28)
msd 6a or msd sci???
AEM fuel rail w/ AEM FPR (damn expensive)?....stock rail with B&M FPR?....STR rail with (whatever FPR will fit)?
walbro in-tank fuel pump
no idea on clutch/flywheel combo...
it's been a long day so that might not be it, but yes, i'm boosting the stock motor. i might look into getting a headgasket since i've read good things about inlinepro. but if i did miss something then please feel free to remind me
Note: i'll be shooting for around 7-9psi daily driven and i'm HOPING for at least 300whp (hey, i can dream can't i?)
Old Aug 4, 2003 | 08:46 PM
hybridreams's Avatar
Default Re: need advice on boosted H22 setup (limeaccord)
What's the stock compression on that motor?
Old Aug 4, 2003 | 08:47 PM
LCDeuce's Avatar
Default Re: need advice on boosted H22 setup (hybridreams)
10.6 i believe.
Old Aug 4, 2003 | 09:06 PM
If that's correct then I would really recommend you atleast get Inline's headgasket to bump down the compression. I'm not saying you can't run the turbo on your stock motor, I just think its better to be a little on the safe side.
Personally I wouldn't go with AEM's FPR. I've heard enough stories of it losing pressure under high loads. Titan Motorsports has an ongoing deal with B&M FPRs.
I don't know if you'd need to worry about getting an aftermarket ignition setup just yet.
Old Aug 4, 2003 | 10:54 PM
GraphiteAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridreams &raquo;</TD></TR><TR><TD CLASS="quote">If that's correct then I would really recommend you atleast get Inline's headgasket to bump down the compression. I'm not saying you can't run the turbo on your stock motor, I just think its better to be a little on the safe side.
yet.</TD></TR></TABLE>
you don't think 300$ for a head gasket is expensive?
Old Aug 5, 2003 | 07:22 AM
Default Re: need advice on boosted H22 setup (GraphiteAccord)
Sure beats a blown motor.
Old Aug 5, 2003 | 08:16 AM
what about a cometic?
Old Aug 5, 2003 | 08:34 AM
ChargedLude97's Avatar
Don't forget injectors.
Old Aug 5, 2003 | 12:45 PM
Prelude Vtec 23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridreams &raquo;</TD></TR><TR><TD CLASS="quote">Personally I wouldn't go with AEM's FPR. I've heard enough stories of it losing pressure under high loads. </TD></TR></TABLE>
I actually researched this, since I am getting it. And no preludes have had any problems w/ it. Only the early models were having problems and those were all on the b motors. Unless the ones having problems didnt want to tell me
Old Aug 5, 2003 | 02:15 PM
LCDeuce's Avatar
Default Re: need advice on boosted H22 setup (Prelude Vtec 23)
what size injectors will i need?
and yes, $300 is damn expensive for a headgasket but i sure as hell don't wanna blow my motor. only question is how thick of a headgasket would be best? what CR?
a friend of mine ran a copper cometic headgasket on his LS turbo and it was crap.
i wouldn't mind trying out an AEM FPR if it wasn't so expensive. rather find something cheaper like a B&M.
Old Aug 5, 2003 | 03:12 PM
Since your doing the Hondata go with like 550's for injectors.
Old Aug 5, 2003 | 03:18 PM
drvfast's Avatar
keep the compression at 10.6. don't buy a thicker headgasket to lower compression. you will be fine as long as you have correct timing, a good fuel managment system, and good tuning. high compression and turbo works good as long as you have good tuning.
Old Aug 5, 2003 | 04:54 PM
LCDeuce's Avatar
Default Re: need advice on boosted H22 setup (drvfast)
still need advice on fuel setup...
Old Aug 6, 2003 | 09:32 AM
LCDeuce's Avatar
ttt
Old Aug 6, 2003 | 11:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limeaccord &raquo;</TD></TR><TR><TD CLASS="quote">still need advice on fuel setup... </TD></TR></TABLE>
you're going hondata, so just get some huge injectors this way the duty cycle is low, and you'll never have worries about running out of injector...i have some CPR 720cc's for sale for 220$ brand new...drop me a pm!
Old Aug 6, 2003 | 04:33 PM
LCDeuce's Avatar
so wait...since i'm getting hondata all i have to worry about is injectors???
Old Aug 7, 2003 | 07:58 AM
redline201's Avatar
nevemind
Old Aug 7, 2003 | 09:53 AM
fastludeh22's Avatar
Default Re: need advice on boosted H22 setup (redline201)
ya,i know someone making 563whp on stock fuel rail. h22 rails are good.
Old Aug 7, 2003 | 03:17 PM
LCDeuce's Avatar
Default Re: need advice on boosted H22 setup (fastludeh22)
563whp on a stock rail? bs
and to redline201....nevermind what?
Old Aug 7, 2003 | 03:23 PM
dubracr18t's Avatar
boost+stock h22=boom. This equation has rang true again and again and again and again. Only a matter of time.
Old Aug 7, 2003 | 04:26 PM
redline201's Avatar
Default Re: need advice on boosted H22 setup (dubracr18t)
i was gonna say you might want a 255lph intank fuel pump
but then i re read the post
Sk8erlude
Jan 2, 2007 07:22 AM
btrim23
May 4, 2006 09:09 PM
DFW
Dec 6, 2004 04:58 PM
graphic
Feb 22, 2004 06:10 PM
LCDeuce
Aug 5, 2003 02:08 PM
