How do you know you have valve float?
Old Aug 4, 2003 | 06:43 PM
hybridEj6's Avatar
Default How do you know you have valve float?
I was just wondering cause I got a Ctr intake cam and a Spoon 8.8 flywheel with stock valve train and stock rod bearings on my b18c When i get on it and then let off Ill hear a pretty loud tick sound sometimes, i know compression breaking is bad with a lightened flywheel(thanx rocket) But when i get on it and then let off in second gear ill hear a loud tick sound
Old Aug 4, 2003 | 06:44 PM
mmuller's Avatar
Mad Scientist
Default Re: How do you know you have valve float? (ekhybrd)
maybe rod bearings going bad
Old Aug 4, 2003 | 06:49 PM
hybridEj6's Avatar
Default Re: How do you know you have valve float? (mmuller)
How do you know your rod bearing are going bad?
Old Aug 4, 2003 | 06:53 PM
mmuller's Avatar
Mad Scientist
ohh, you have stock valvetrain so it could also be valve float.how do you know?by sound. describe a little better what it does.
Old Aug 6, 2003 | 06:40 PM
hybridEj6's Avatar
just say i get on it first and second and then let off in second i will hear a audible tick sound just one. I think my mounts are pretty much worn so maybe the engine is hitting something
Old Aug 6, 2003 | 06:48 PM
mmuller's Avatar
Mad Scientist
is it one thump?like brbrbrbrbrrrrrrrr, let off the gas, thump if it does that;maybe
Old Aug 6, 2003 | 08:08 PM
MikeSarr_GSR's Avatar
it could be your valvetrain bottoming out when you downshift hard, or is it as it sinks back in the RPMs? if it is what I think it is... its the rocker shafts depressurizing and the VTEC pistons in the rocker arms dismounting.
all VTEC cars do it occasionally. yours could be on the verge of being worn.
this is something that gets louder as the motor gets older. it makes the sound
as VTEC un-mounts.
get some real damn springs and LMAs on your cams damn it!
Old Aug 6, 2003 | 10:01 PM
hybridEj6's Avatar
Default Re: How do you know you have valve float? (MikeSarr_GSR)
yeah i know, ima get those new mounts from has port and get some valve springs, i might just go get prelude LMAs and put a .040 inch spacer on it
theslugbug
Jul 10, 2008 04:02 AM
teamvirus
Oct 25, 2006 04:50 AM
CRISIS
Apr 17, 2006 05:06 AM
hYbRid_Eg6
Jun 3, 2004 01:53 AM
Veil_Side_
Nov 29, 2001 08:23 PM
