Help! Map signal pin?
Old Aug 4, 2003 | 08:39 AM
spooned out's Avatar
Default Help! Map signal pin?
i need to knoe if D17 is the correct pin for the Map signal and if the color on the wire is Pink/White? it says solid white on hybridegarage but pin location is D17.
Old Aug 4, 2003 | 10:54 PM
Esoterikos's Avatar
Default Re: Help! Map signal pin? (spooned out)
the one source i have found also says solid white. are you sure the pink isn't just something on the wire that isn't supposed to be there?
also, thanks a lot for giving me the idea to look up the ecu pinouts on hybrid garage. that was a big help in something else i'm doing!
Old Aug 5, 2003 | 09:37 AM
no prob, but on the slot D17 for the p28 and p30 is the Map signal but its not the solid white color its a pink/white...
anyone with knowlegde of ecu wire colors?
B18EG6
Mar 28, 2007 12:36 PM
ItsStockOfficer
Apr 8, 2005 08:27 PM
spooned out
Aug 5, 2003 08:32 AM
InTeGrA B18b1
Jun 24, 2003 10:45 AM
xXx Justin xXx
Jun 18, 2003 09:49 AM
