Ericks TB
Old Aug 3, 2003 | 02:03 AM
AussieK24's Avatar
Default Ericks TB
Is there any benefit to getting an Ericks 67mm throttle body as opposed to any other 67mm TB? I've got a 67mm TB off a jap import and was wondering are there any tricks in the Erick one or is a 67mm hole a 67mm hole?
Old Aug 3, 2003 | 03:44 AM
advanracing62's Avatar
Default Re: Ericks TB (AussieB20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AussieB20vtec &raquo;</TD></TR><TR><TD CLASS="quote">is a 67mm hole a 67mm hole?</TD></TR></TABLE>
oooo so many ways to go from there...
I'm guessing that the Erick's TB is tapered, maybe 70-67 taper. Which, as we all know, would be for velocity. I'll let someone with experience in Erick's racing talk a bit more about that.
Old Aug 3, 2003 | 07:17 AM
Tbone's Avatar
I run the erics unit. it's 70 at the mouth and tapers to 68 at the plate. The noticable difference I can see is that it has a tighter return spring than some of the others , so it doesnt stick as much..my bbk one got stuck wide open a few times.
Old Aug 3, 2003 | 07:44 AM
AussieK24's Avatar
Default Re: Ericks TB (Tbone)
I dont suppose you did before/after with the TB? I'm still running the 58mm B16 Tb and would like an idea of the improvement available with a Ericks TB.
Old Aug 3, 2003 | 12:42 PM
b19coupe's Avatar
Here is what Erick's 70-68mm TB did on my Skunk2 Stage 2 cammed engine:
https://honda-tech.com/zerothread?id=382714&page=2
This was vs stock 62mm Type-R TB.
Old Aug 4, 2003 | 01:38 AM
AussieK24's Avatar
Default Re: Ericks TB (b19coupe)
So I take it the gains will be more going from 58mm??
Old Aug 4, 2003 | 05:32 AM
b19coupe's Avatar
I suspect that the gains would be more, only one way to find out for sure...
meanshyguy
Sep 28, 2008 08:28 PM
eymnewdc4
Nov 22, 2005 04:30 PM
MysteriousGSR
Oct 24, 2005 02:34 AM
MugenPoweredLude
Aug 10, 2003 06:20 PM
