Oil Leak! I Think the mechanic did it!
Old Aug 1, 2003 | 09:59 AM
NINJA's Avatar
Default Oil Leak! I Think the mechanic did it!
Researched the search section...
I have a similar problem discussed in post:
https://honda-tech.com/zerothread?id=502398
I'm leaking oil from the filter area... I just got an oil change and it immediately started afterwards. Now the mechanic who did the oil change says that my "oil seal" has gone bad and that to replace it involves dealing with the "drive shafts" and is laborious in general.
This sounds suspect to me, any advise?
Seems like he misthreaded the filter to me?
Old Aug 1, 2003 | 10:16 AM
uNF$@#!'s Avatar
Default Re: Oil Leak! I Think the mechanic did it! (NINJA)
perform another oil change.
buy your own filter, jack it up, lube the gasket on the filter with oil before install.
spray down block/clean it with simple green
Old Aug 1, 2003 | 10:21 AM
PyR01-0347's Avatar
Well it sounds like he is trying to weasel his way out of his mistake. If it is just coming from oil filter, it sounds like the oil seal on the filter is bad or he didn't tighten down the oil filter. Which means that you need to get a new oil filter or just tighten it down. You definently don't need new driveshaft oil seals. Unless the oil is coming where the driveshaft connects to the tranny.
Old Aug 1, 2003 | 10:24 AM
RaVAGE00's Avatar
New User
Default Re: Oil Leak! I Think the mechanic did it! (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldnt brake cleaner be better since it dry without leaving anytype of residue behind......
Old Aug 1, 2003 | 11:49 AM
NINJA's Avatar
Default Re: Oil Leak! I Think the mechanic did it! (RaVAGE00)
I've heard that a double gasket on the filter can cause a leak.
Any insight on this guys?
Old Aug 1, 2003 | 11:51 AM
Asahi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJA &raquo;</TD></TR><TR><TD CLASS="quote">I've heard that a double gasket on the filter can cause a leak.
Any insight on this guys?</TD></TR></TABLE>
Double gasket doesn't leak it pours. It is most likely not a double gasket.
Old Aug 1, 2003 | 11:57 AM
NINJA's Avatar
Default Re: Oil Leak! I Think the mechanic did it! (Asahi)
So is there a seal that could go bad where you attach the filter (not the filter seal)?
Old Aug 1, 2003 | 12:16 PM
00MRSi's Avatar
Default Re: Oil Leak! I Think the mechanic did it! (PyR01-0347)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyR01-0347 &raquo;</TD></TR><TR><TD CLASS="quote">Well it sounds like he is trying to weasel his way out of his mistake. If it is just coming from oil filter, it sounds like the oil seal on the filter is bad or he didn't tighten down the oil filter. Which means that you need to get a new oil filter or just tighten it down. You definently don't need new driveshaft oil seals. Unless the oil is coming where the driveshaft connects to the tranny.</TD></TR></TABLE>
That's what I'm thinking. Your "mechanic" sounds like a jerk off. Find another one.
Old Aug 1, 2003 | 07:49 PM
EK MONEY's Avatar
Default Re: Oil Leak! I Think the mechanic did it! (00MRSi)
last time I had someone do work for me, I came back and I my R smelt like burnt tire. The car was there for only 2 hours, and the gauge was at cold!!! They did a monster burn out in my car with the engine cold Thats when I learned to do all my own stuff....
Old Aug 1, 2003 | 09:47 PM
EG8R's Avatar
I've done that!!! Oops. Makes one heck of a mess right away....
Old Aug 2, 2003 | 11:56 AM
b18c-rDC2's Avatar
Default Re: Oil Leak! I Think the mechanic did it! (mr. skelly)
From now on just change your own oil...problem solved! Like many others have said you probably just need a new filter or YOU could perform another oil change.
DelsolVted
14
Mar 15, 2011 08:12 PM
chiaxi2002
Apr 9, 2010 08:56 PM
italstallion
Sep 5, 2007 12:08 PM
RAB
Jul 20, 2002 01:01 PM
degradated
Oct 29, 2001 07:32 PM
