anybody run without their eacv?
Old Aug 1, 2003 | 02:21 AM
carsaregood's Avatar
Default anybody run without their eacv?
i swear, my car runs better with it disconnected. throttle response is better, idle is more stable... etc. the only downside is that i have to manually rev it when its cold to warm it up... so i wired in a switch and can turn it on only for warming it up. anybody do anything like this? any possible downsides in doing this?
Old Aug 1, 2003 | 03:12 AM
JonGP4's Avatar
Default Re: anybody run without their eacv? (carsaregood)
uh yeah it throws a check engine light, and makes the computer run really rich. so downside very poor gas milage and u will need spark plug pretty often. Thats why ur car "feels" better.. if u don't care then more power to ya, personaly i think its pretty dumb
Old Aug 1, 2003 | 09:40 AM
Default Re: anybody run without their eacv? (JonGP4)
i've been running with it unplugged and i haven't noticed my gas mileage go down at all... i still get around 32+ mpg on the freeway with my zc with an si 5speed and jun flywheel.
Old Aug 1, 2003 | 09:49 AM
raene's Avatar
You could remove it from the IM and cap off the hole if you wanted.
Old Aug 1, 2003 | 11:52 AM
Default Re: anybody run without their eacv? (raene)
yeah thats true, but then i wouldn't have the fast idle on startup... any other thoughts on this? thanks for the replies so far.
Old Aug 1, 2003 | 12:01 PM
raene's Avatar
Heheh, well, that's the price you pay man What you're looking for is a switch to disconnect it, but the computer can tell when it's not functioning and throws that CEL. If you managed to wire in some sort of a bypass circuit with a total resistance roughly the same as the IACV resistance (measure it with a multimeter) then you could probably get around it, but again, that's something you'd have to flip when the car warmed up. Or you could somehow trigger that by using a temp-dependent switch operated on output from a water temp gauge with an output trigger.
Just random thoughts - but what you're looking to do wouldn't be easy!
Old Aug 1, 2003 | 01:16 PM
hmmm interesting raene! thanks for the great reply again.
ok, i think my question is more about what happens when the cel comes on. does the ecu go into some kind of base fuel map? if so, is there any harm in just running it that way? sorry if these are stupid questions but i don't know much about electronic fuel injection.
Old Aug 1, 2003 | 02:06 PM
raene's Avatar
I have no idea, sorry! If you've got an air/fuel meter like an Autometer fancy flashing light display you can use that to see if the ECU is going into closed-loop mode or staying in open-loop. But unless someone knows for sure, I can't say!
I've tried to drive with an IACV code before (IACV died at autocross) and the car shudders + really isn't happy during driving (JDM PR3 ECU). Kinda strange that yours drives better.
blkdoutteg
Sep 19, 2019 10:21 AM
LSej1
Honda Civic (2001 - 2005)
Sep 3, 2017 10:44 AM
dano126
Nov 15, 2010 03:23 PM
nemoy
Jul 12, 2009 04:52 PM
sherman19
Dec 27, 2002 07:15 PM
