what is wrong with my tranny?................
Old Aug 7, 2001 | 09:42 AM
hobo79's Avatar
New User
Default what is wrong with my tranny?................
my 3rd gear grinds when i go over 3000rpm. what is wrong????........also, this is my first manual car so i am wondering whether slight vibrations at times is normal with the shifter as well as the brake n clutch?
Old Aug 7, 2001 | 05:36 PM
GeeSeeR's Avatar
New User
Default Re: what is wrong with my tranny?................ (hobo79)
synchros
Old Aug 7, 2001 | 06:06 PM
G's Avatar
G
Default Re: what is wrong with my tranny?................ (GeeSeeR)
I second that....
Old Aug 7, 2001 | 06:19 PM
BreakStuff's Avatar
New User
hold on..
3rd gear grinds when you are already in 3rd and go over 3000 rpm's?
or
when you go over 3000 rpm's and shift into 3rd?
Old Aug 7, 2001 | 06:29 PM
G's Avatar
G
Default Re: what is wrong with my tranny?................ (BreakStuff)
Now I am wondering..... he didn't mention when he shifts......
Old Aug 7, 2001 | 07:57 PM
hobo79's Avatar
New User
Default Re: what is wrong with my tranny?................ (G)
i'm on 2nd gear and hitting over 3000rpm....then i shift to 3rd, thats when it grinds. if i shift under 3000rpm, it is good.....only when rpms are high, n then i shift, then it grinds
Old Aug 7, 2001 | 11:12 PM
raene's Avatar
Yeah, that sounds like a shot synchro.
The vibration of the shifter lever is probably normal. Honda uses a directly-connected shifter, meaning the shifter is literally bolted onto the engine via a pair of bars. Other cars frequently use a cabling system to circumvent the noise/vibration/harshness factor, but it makes for a softer shift. Honda chose to go with the more direct-action shifter.
Old Aug 8, 2001 | 01:54 AM
JDM_DOHC_SiR's Avatar
New User
Default Re: what is wrong with my tranny?................ (raeneshadow)
do you have this problem when lets say you are in 2nd and rev the **** out of it and push the clutch in but.....wait a second and then slowly shift...Does it still grind..If it does then my friend your syncro's are about to take a trip to the darkside If not then I would flush the tranny and get new oil " HONDA MTL " Keep us updated
Old Aug 8, 2001 | 09:11 AM
hobo79's Avatar
New User
Default Re: what is wrong with my tranny?................ (JDM_DOHC_SiR)
yes it does.......so since i bought the car within a month ago and have warranty, they should fix it for free right? how much would it cost to fix that if i didnt have warranty? THANKS FOR THE HELP
Hephro.T
Sep 27, 2016 11:22 PM
EG6 Love
Dec 10, 2010 07:04 AM
cr-x si
Jun 15, 2003 05:36 PM
slow02ss camaro
Jan 20, 2003 06:20 PM
dose
16
Oct 5, 2002 07:40 AM
