Short shift adapter vs Short shifter
Old Jul 31, 2003 | 06:20 AM
Modifiyem's Avatar
Default Short shift adapter vs Short shifter
I see that short shift adapter is much cheaper than the short shifter for 98ls.
does the short shift adapter do the same job as the short shifter?
Short shift adapter seems easy to put on, but the short shifter seems pain in the neck.
If the short shifter reduces the throw by 40%, would the short shift adapter would reduce it as much as the shifter?
Thank you
Old Jul 31, 2003 | 06:30 AM
Passaudi1.8t's Avatar
New User
Default Re: Short shift adapter vs Short shifter (Modifiyem)
Short shift adapter for a Teg? I thought they were for Accords and 'Ludes that have cable-operated linkages. Civics and Integras use a direct linkage that goes underneath the car, so you would swap out the shift lever to reduce the throw. The adapter plate on Accords and Preludes just cuts the distance between the cables and the transmission.
starbury
Feb 15, 2005 09:58 AM
Modifiyem
Jul 30, 2003 09:43 AM
2k1_ITR_0736
31
Jul 20, 2002 08:41 AM
SOHC_MShue
Jun 20, 2002 02:44 PM
ArchAngel Sabastian
Feb 2, 2002 12:09 PM
