What can I use 5/16" Stainless line for? What -AN is that?
I have access to a few feet of 5/16" Stainless Steel line that I want to use. A few questions:
1) Dont most SS lines go by AN size? What is 5/16" AN?
2) What can I use this size line for? I'm working on boosting a D16 with a T25 turbo, so if I can use it for that project then great.
3) If I cant use that line for turbo, is there anywhere I can use it on my '94 Civic EX?
Thanks
Thanks
When looking at stainless steel braided lines, you need to look at the Outside Diameter for fitment and inside for flow. 2 lines both with 1/4" Inside diameter may have a different number for outside diameter. The hose ends fitting can only be match with the ouside diamter of the lines for perfect fit. And that's is measure by AN standard measurement
stan
stan
