car wont pull...
Old Jul 30, 2003 | 08:04 PM
tour de france turbo's Avatar
Default car wont pull...
ok i made a post awhile back about my engine bogging and not making power.
https://honda-tech.com/zerothread?id=573283
i replaced the cap and rotor along with a new fuel pump. fuel pressure doesnt drop now. but it sounds like is miss fires and bogs even worse then before. any ideas for me guys?
Old Jul 30, 2003 | 09:04 PM
Malgerus's Avatar
Default Re: car wont pull... (stock ek sleeper)
check the ignitor/coil...
Old Jul 30, 2003 | 11:00 PM
mmuller's Avatar
Mad Scientist
Default Re: car wont pull... (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">check the ignitor/coil...</TD></TR></TABLE>
second that, bet is bad ignitor.
you still have your psi set at 75?
Old Jul 31, 2003 | 04:21 AM
1bad-eg's Avatar
Old Jul 31, 2003 | 10:22 AM
Default Re: car wont pull... (1bad-eg)
what will i be checking for to see if its bad? any tests?
Old Jul 31, 2003 | 10:23 AM
and the psi is at 60. tried it form a range of 40-65, still no cigar
Old Jul 31, 2003 | 11:52 AM
Old Jul 31, 2003 | 12:38 PM
mmuller's Avatar
Mad Scientist
if you keep the psi at 60 get ready to buy a new fuel pump and injectors.....cant believe nobody told you to turn it down to STOCK.
most likely is your ignitor, try swapping it
Old Jul 31, 2003 | 03:33 PM
Default Re: car wont pull... (mmuller)
i got a new fuel pump and think one of the injectors is bad. but how would i be able to tell if its the ingnitor or the injectors. i just spent 200$ on a new fuel pump, cap and rotor to fix the problem. im now tryin to follow the rules of bidget racing lol. any input would be thanked
Old Aug 1, 2003 | 07:17 PM
ttt
Old Aug 1, 2003 | 07:30 PM
mmuller's Avatar
Mad Scientist
well, the symptoms that you have are not of a bad injector.
cant you swap the ignitor out of one of your friends or some. to see if thats it?
Old Aug 1, 2003 | 07:34 PM
Mohudsolo's Avatar
If it's a bad injector, the plug on that cylinder should be a very different color than the rest. Probably the ignitor or coil though.
Old Aug 1, 2003 | 11:40 PM
RICE POLICE SIP's Avatar
Default Re: car wont pull... (Mohudsolo)
yeah i'de probaly say it's the ignitor or coil... you didn't wash your engine lately have you?
Old Aug 5, 2003 | 04:01 PM
Default Re: car wont pull... (92boostn'hatch)
sorry been busy at work, but no the engine wont pull still thinking it might be the ECU. cause the car will run prime when its not warmed up. like if i let it sit for 5 mins then take it out and dont let it warm up to running temp. it runs good. but then it seems like once sumthing warms up thats where my problems come from. ignitor and coil appeared to be good. i could be wrong is there a test to do on them that i could try? i also tried replacing the O2 sensor and it still runs like ****
Old Aug 6, 2003 | 07:02 AM
T4eg's Avatar
id check the distributor
Old Aug 6, 2003 | 02:57 PM
Default Re: car wont pull... (BlueHatch00)
thing is driving me crazy, car will never bog when its just started up and not warm, but as soon as it warms up it turns into bogging POS.
iixerOii
Honda Fit
Nov 29, 2007 07:29 AM
Pitfan04
Honda Civic (2006 - 2015)
Mar 19, 2007 06:16 AM
sprayedcrx
20
Aug 2, 2005 09:51 PM
SpoolinEK
Dec 10, 2003 02:28 PM
allmtr
Jul 10, 2003 02:40 PM
