Ground Wire
Old Jul 30, 2003 | 11:54 AM
brian estrada's Avatar
Default Ground Wire
Ok, so what does the ground wire that goes from the valve cover to that bold next to the headlight do? A friend of mine broke it off yesterday working on his car... I didn't know what to tell him. The car runs fine, and the headlights are working fine... It's not something that's hard to fix, but i've just gotten curious thinking about what it does.
thanks
Old Jul 30, 2003 | 11:57 AM
Malgerus's Avatar
Default Re: Ground Wire (jchxcrx)
It's just another ground. Replace it if you can, or better yet get bigger wire. I've heard it can make your stereo and headlights work better if you upgrade.
Old Jul 30, 2003 | 12:18 PM
neutron91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jchxcrx &raquo;</TD></TR><TR><TD CLASS="quote">The car runs fine, and the headlights are working fine...</TD></TR></TABLE>
thats very strange... mine came loose once and ran like total ****... major power loss... and my clock and cd player flickered on and off
Old Jul 30, 2003 | 12:19 PM
dingusjt's Avatar
Default Re: Ground Wire (Mr. S)
yeah just get some 8 gauge amp wire works great and looks really clean too...then you can just get clamp connectors at any hardware store to fit it.
Old Jul 30, 2003 | 12:29 PM
Hcivic88's Avatar
Default Re: Ground Wire (dingusjt)
you should replace it.
how do you break a wire while working on your car anyways? what was he doing??
Old Jul 30, 2003 | 01:25 PM
Default Re: Ground Wire (Hcivic88)
I think he said that he was trying to tighten the bolt that it goes on by the headlight and just broke the wire... i don't know, after a while those kind of things can just get brittle... get bent back and forth too many times and decide to go one day. My check engine light came on once, showing the coolant temp sensor... turned out to be the wires that go into the sensor just broke... Anyway, I went to a stereo shop downtown and bought him some 8guage stinger wire for $.50.
thanks
Old Jul 30, 2003 | 05:57 PM
emwavey's Avatar
Definitely replace it.
I took my car to a mechanic, once, and he knocked off a ground wire that apparently exists underneath the car somewhere. After a month and a new distributor, I visited the crxresource and some nice guys suggested this was the problem...
Tach jumped, car stuttered and eventually it would die and not start... all from a disconnected ground wire.
Old Jul 30, 2003 | 06:01 PM
FourthGenHatch's Avatar
Default Re: Ground Wire (emwavey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emwavey &raquo;</TD></TR><TR><TD CLASS="quote">Definitely replace it.
Tach jumped, car stuttered and eventually it would die and not start... all from a disconnected ground wire.</TD></TR></TABLE>
Probably the Thermostat ground. Its not under the car, there are none under the car, but its sort of in the back. I hear that messes up your car a whole bunch.
Old Jul 30, 2003 | 11:59 PM
RuthlessEF-9's Avatar
thats the charging ground i think
one of the threee grounds inside the hood
lowtegsr
Aug 18, 2008 01:32 PM
jordan_civic
Oct 15, 2007 03:03 PM
lakerschamp2000
Sep 5, 2007 04:23 PM
Leo.
Nov 8, 2006 03:03 PM
ace42004
Audio / Security / Video
Aug 4, 2004 05:39 AM
