HELP ME OUT
Old Aug 2, 2004 | 03:47 PM
ace42004's Avatar
Default HELP ME OUT
alright i got my cd player to finally work but when i turn my headlights on it dies..and as soon as a turn off my headlights the cd player works...whats wrong...did i wire something wrong...everything works but that...thanks..oh and its a clarion if that helps any...
Old Aug 2, 2004 | 04:10 PM
Eric R's Avatar
Default Re: HELP ME OUT (ace42004)
Did you hardwired the radio, or did you used a wire harness adaptor?
Need info.
Old Aug 2, 2004 | 04:12 PM
teamxtant's Avatar
What you did was you hooked your ground wire to your illumination wire. This is the wire that turns to 12v when you turn on your lights. Therefore, when you turn on your lights, you cut off your ground. Hook the black wire of your deck to some sort of metal behind your dash and it will work fine. Or tel me what kind of car you have and I can tell you what stock wire to hook it to.
Old Aug 2, 2004 | 04:22 PM
ace42004's Avatar
Default Re: HELP ME OUT (teamxtant)
IM using a wire harness....its on a 96 dx hatch
Old Aug 2, 2004 | 04:34 PM
Eric R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace42004 &raquo;</TD></TR><TR><TD CLASS="quote">IM using a wire harness....its on a 96 dx hatch</TD></TR></TABLE>
Recheck you connetions on the wire harness. Make sure you're not using a negative dimming connection as a switch on power. If possible, use a multimeter or test light to confirm the function on each wire in the radio plug once disconnected.
Eric
Old Aug 2, 2004 | 04:39 PM
Eric R's Avatar
Default Re: HELP ME OUT (Eric's R)
Correction: 96 DX Hatch has a positive dimmer pulse, so check your wiring at the harness or there might be a problem with the radio.
Old Aug 3, 2004 | 04:46 AM
ace42004's Avatar
thanks for all the help..got it fix...
Old Aug 4, 2004 | 02:10 AM
teamxtant's Avatar
So what was the problem?
Old Aug 4, 2004 | 05:39 AM
ace42004's Avatar
i hook up the wrong wires..like what u guys say..u guys are the best...
lakerschamp2000
Sep 5, 2007 04:23 PM
fergs96integra
Audio / Security / Video
23
May 22, 2006 09:17 AM
civiccoupe94
Mar 2, 2006 09:08 PM
mikecivichb
Apr 4, 2004 10:05 AM
RAWbertCuBus
Sep 19, 2003 07:02 PM
