I still have a code 6 after replacing the ECT sensor WTF!?!?!?
Old Jul 30, 2003 | 07:38 AM
Nerv2g's Avatar
Default I still have a code 6 after replacing the ECT sensor WTF!?!?!?
Ok I had/have a code 6, engine coolant tempreture sensor, I replaced the sensor but still have the CEL. What did I miss or do wrong? All help will be apprecaited. Thank you
Old Jul 30, 2003 | 08:16 AM
1_bad_EF's Avatar
Default Re: I still have a code 6 after replacing the ECT sensor WTF!?!?!? (Nerv2g)
check the connector... pins may be bent and not making contact. what kind of car? engine? done any wiring mods lately?
Old Jul 30, 2003 | 10:10 AM
UNDER PRESSURE's Avatar
Default Re: I still have a code 6 after replacing the ECT sensor WTF!?!?!? (1_bad_EF)
Have you reset the ecu?
Old Jul 30, 2003 | 10:14 AM
1_bad_EF's Avatar
reseting the ecu wont do it. If the ignition is turned on the ecu does a system check and then throws the code its usually a wiring problem. If it goes on while driving, most times, its a defective sensor.
Old Jul 30, 2003 | 10:33 AM
Default Re: (1_bad_EF)
The ecu must be reset.
Old Jul 30, 2003 | 10:47 AM
Nerv2g's Avatar
Default Re: (UNDER PRESSURE)
Thanks for the quick replies. I have not done any wiring lately, the motor is a b18c5 and the car is a 92 civic vx. I just replaced the sensor today. I thought that I rest the ECU, I took the + battery cable off and took out the fuses buy the shock tower. I started up the car the CEL did not comes on at first but then about 2 seconds later it was there mocking me. How do I properly reset the ecu? maybe I did it wrong. Thanks agian for your help
Old Jul 30, 2003 | 10:55 AM
1_bad_EF's Avatar
Default Re: (Nerv2g)
reset the ecu=pull the hazard and ecu fuses from the underhood fusebox.
check you grounds w/ a ohmmeter.
Old Jul 30, 2003 | 11:57 AM
Is the same code still popping up or is it another one. And also do exactly what 1_bad_EF said "check your grounds" and connections.
Old Jul 31, 2003 | 06:21 AM
Nerv2g's Avatar
Ok I checked all the plugs and on the ground on the thermostat housing I even used sand paper to "clean" the area. I started up the car and the idle was smooth then about 1 minute later the CEL came back on and the idle was higher again, WTF!?!?!?!?!?
Old Jul 31, 2003 | 06:32 AM
1_bad_EF's Avatar
is the valve cover grounds hooked up? these are very important. you have to make sure the ground is on a valve cover stud and the chassis. what car/engine?
IM me if you want
Old Jul 31, 2003 | 09:52 AM
hondaR's Avatar
wire it stright to the ecu.
Old Jul 31, 2003 | 07:29 PM
Nerv2g's Avatar
Default Re: (hondaR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaR &raquo;</TD></TR><TR><TD CLASS="quote">wire it stright to the ecu.</TD></TR></TABLE>
How do I do that?
Old Aug 10, 2003 | 08:42 PM
hondaR's Avatar
what year is your car and what make is it, ill check the ecu pins for you and ill let you know
Navy_Kyle
Aug 18, 2012 02:02 PM
REDREXMANB16
Nov 23, 2006 09:54 PM
Dc_Ek
Aug 9, 2006 08:28 AM
Gimp
Mar 4, 2004 02:14 PM
incognitoracerr
Jan 11, 2004 07:13 PM
