Car Won't Start....
Old Jul 30, 2003 | 07:29 AM
JBG's Ferio's Avatar
Default Car Won't Start....
Well we just replaced the head, got everything hooked up. Got rid of the 2 CEL's it was throwing (15, and 41). But car still won't start. I have NGK laser platinum plugs (not pre-gapped and I haven't adjusted the gap.) New, wires, etc. Car acts like it wants to start but it won't. Any Ideas?
BTW: This is a 1992 Prelude Si.
Any help is GREATLY appreciated.
Old Jul 30, 2003 | 07:42 AM
b18bcivic's Avatar
Default Re: Car Won't Start.... (J B G)
do u have fuel?check the gap on the plugs too.
Old Jul 30, 2003 | 07:44 AM
Default Re: Car Won't Start.... (b18bcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bcivic &raquo;</TD></TR><TR><TD CLASS="quote">do u have fuel?check the gap on the plugs too.</TD></TR></TABLE>
yes, it is getting fuel. the plugs are sparking. this is why I'm so confused.
Old Jul 30, 2003 | 07:52 AM
foot's Avatar
Check your timing.
Old Jul 30, 2003 | 11:28 AM
anyone else with any insight?
Old Jul 30, 2003 | 12:29 PM
turbochic's Avatar
Default Re: Car Won't Start.... (foot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foot &raquo;</TD></TR><TR><TD CLASS="quote">Check your timing.</TD></TR></TABLE>
yeah a friend of mine had the same problem, timing belt was off, also make sure your distributor isnt 180 degrees off
Old Jul 30, 2003 | 01:48 PM
wenlyone's Avatar
timing is the first thing you sould check.
make sure you put some dielectric grease into the boot.
what do you mean it wants to start.
can you describe in more detail?
Old Jul 30, 2003 | 03:09 PM
chictunner97ex's Avatar
Default Re: (wenlyone)
hey just like fmaxtrubochic said i am the friend that had the same problem, what is your compression? check your timing and the distributer can go on two ways, the correct way which is pointing to number one wire, or 180 degrees opposite of the number one. also make sure you are definatly on the intake with the valves not the exhaust when you go to TDC the cam and the crank. i hope this helps you out, but let me know what your compression is through the Im or thread it, let me know if you need anything else and good luck gloria
Old Jul 30, 2003 | 03:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wenlyone &raquo;</TD></TR><TR><TD CLASS="quote">timing is the first thing you sould check.
can you describe in more detail?</TD></TR></TABLE>
It turns and turns and turns, and then it will start, then die like a half second later.
Based on all your replies. I'm going to concentrate on getting the timing correct. Then if it still won't start, diagnose problems from there.
Thanks again
Old Jul 30, 2003 | 04:29 PM
MightyMouseTech's Avatar
Default Re: Car Won't Start.... (fmaxturbochic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmaxturbochic &raquo;</TD></TR><TR><TD CLASS="quote">
Don't worry about checking this, it is physically imposible to set a Honda distributor 180deg off.
Did you mark the timing belt and cam gears before you pulled the belt off? On those engines, I can almost gaurantee one of the cam gears jumped a tooth unless you marked it first. Belts on those cars can be a pain to line up properly.
Old Jul 30, 2003 | 06:41 PM
poison's Avatar
Default Re: Car Won't Start.... (MightyMouseTech)
John, you said you got compression tests, what were the results?
lilmisshonda
Jul 2, 2008 06:43 AM
TheSiWay
Jun 21, 2008 07:21 PM
iceman7329
Jul 12, 2007 11:12 AM
edsymister
Jul 27, 2006 06:31 PM
eg6cusco10pt
Sep 29, 2005 09:19 PM
