Hondata Base Map
Is there anyone here running the Hondata just using the base map with bigger injectors? The reason I ask is because I would like to go ahead an install the EEprom into the P28 and install 440 injectors and use basemap that came with the chip untill I have the car tuned. I would like to install this now so I will save time when I travel to get the car tuned.
you can try a uberchip for that but trying to ride around on a hondata basemap isfuckin stupid im sorry bro, but thoose base maps are meant to dump a *** load of feul so you can get to the dyno and get your car tuned.
good luck
good luck
Boosted thanks for the reply, however it may just do exactly what I need it to do if it's possible. I have to travel 3hours away to have the car tuned. I would like to work out any issues with ECU before going somewhere just to find out it can't be tuned. So yes it's probably like the Blue Box but it's better to be safe than sorry for about 2 days before I get the car tuned.
