Hole on oil pan=blown engine?
Old Jul 30, 2003 | 01:08 AM
EF7's Avatar
EF7
Default Hole on oil pan=blown engine?
My friend was driving my CRX on the way to pick me up, when he got to the train station he said that my engine was making funny noises, I looked under the hood and everything looked fine when I looked at the oil pan I saw a hole about 1/2 diameter and it looks that something hit it form the inside. the hole is located on the upper front part of the oil pan, the engine starts but it is really loud, there is not check engine light or ECU flashes, the only thing that lighted up was the oil light but i guess it is because the oil level is low. The engine is a ZC with 59000kms.
Any help or ideas will be appreciated, thanks!
Old Jul 30, 2003 | 01:49 AM
acuracing's Avatar
Default Re: Hole on oil pan=blown engine? (EF7)
You could have hit something while driving or a rock shot up and hit it.
Old Jul 30, 2003 | 06:50 AM
mike1114's Avatar
Default Re: Hole on oil pan=blown engine? (acuracing)
engine is fine. I had my header rub a hole in my oil pan once, major smoke was coming from bottom of car for a while before I figured it out. Just re-weld oil pan or buy new one and you'll be okay, as long as you didin't drive it too long without enough oil in the car.
Old Jul 30, 2003 | 08:14 AM
IN VTEC's Avatar
Any loud clanking noises?
Maybe you lost a connecting rod nut at high rpm and knocked a dent/hole in the pan.
If the sound is pre-dominantly from the bottom of the engine you should look into pulling the pan to see if anything came loose.
Old Jul 30, 2003 | 08:35 AM
92sleepR's Avatar
New User
Yeah, usually
Certainly if you ran it like that.
Mike
Old Jul 30, 2003 | 08:39 AM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the only thing that lighted up was the oil light but i guess it is because the oil level is low</TD></TR></TABLE>
Maybe you did lose a connecting rod nut. Opening up clearances on a rod might drop the pressure low enough to turn on the dummy light.
Better get ta lookin'.
Old Jul 30, 2003 | 08:59 AM
1_bad_EF's Avatar
Default Re: Hole on oil pan=blown engine? (IN VTEC)
Dont drive it!!!!!!!! your buddy prolly bottomed out the oilpan into the oil pickup. If the oil light is on and the engine is running then engine damage WILL occur. Connecting rod nuts just dont come loose if the engine wasnt taken apart previously...........Or it threw a rod but didnt come through the block (prolly not tha case)
Old Jul 31, 2003 | 08:10 AM
1_bad_EF's Avatar
Default Re: Hole on oil pan=blown engine? (1_bad_EF)
well what was it?
Old Aug 5, 2003 | 12:37 AM
EF7's Avatar
EF7
Well, i took the oil pan an the head off, rod #4 is gone, I guess I'll start looking for another car.
Anyone wants parts off of an JDM EF7? got almost everything.
email: japanpartsonline@hotmail.com
Old Aug 5, 2003 | 12:44 AM
IN VTEC's Avatar
Default Re: (EF7)
Too bad about the damage.
What time is it there? Like 1:44PM? Konnichiwa dawg. Man I need to go to bed.
PNK SLP
Mar 23, 2008 05:11 PM
JMigs
Dec 17, 2004 03:37 PM
Preludster
Nov 28, 2003 04:55 PM
89 CRX SI
Aug 31, 2002 09:07 PM
