Is there any way of physically affecting VTEC...
Old Aug 6, 2001 | 02:42 PM
jayson roman's Avatar
New User
Default Is there any way of physically affecting VTEC...
I know how vtec can be affected by electronics, but say someone does a bad valve adjustment, or put on a timing belt too lose, or something phycial to the engine, can vtec be affected???
Old Aug 6, 2001 | 03:59 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Is there any way of physically affecting VTEC... (jayson roman)
VTEC won't be directly affected. BUT it will affect everything else like timing, valves, etc....
Old Aug 13, 2001 | 10:04 AM
jebarco1's Avatar
New User
Default Re: Is there any way of physically affecting VTEC... (B18C-EJ1)
lack of oil or oil pressure can affect VTEC. The soleniod release oil in to the rocker arm rod, and down to pins in the rocker arm assembly which locks third vtec lobe into the timing of the two valves give you advance timing and third vtec cam profile. So im thinking a crack in the rod, or some kinda link in the head, or rocker-arm assembly can affect the profile of one valve thus throwing all the head off. later
Old Aug 14, 2001 | 06:48 AM
Stinkalope's Avatar
New User
Same concept about oil pickup problems........Sometimes if you abuse your oil pan too much you can bend the pickup and the vtec will not come on. Mine works but my pan is trashed from previous owner so I am changing mine soon.
cloudconnected85
Oct 4, 2008 07:32 PM
AXZ NYC
Feb 13, 2005 09:07 AM
DIYMIKE
May 30, 2004 11:46 AM
jared703
Dec 13, 2001 09:46 AM
BoM
Oct 2, 2001 05:59 PM
