VTEC, it pulls then it doesn't? whats wrong?
Old Oct 1, 2001 | 04:30 PM
BoM's Avatar
BoM
Default VTEC, it pulls then it doesn't? whats wrong?
okay...i just noticed this, i take it in vtec third gear....6k rpms, pullssss, then goes to 7k rpms and it stops pulling for a moment, then pulls againnnn...
what can this problem be?
status of the car is:
85k miles, timing belt soon...and i hear my valves clicking....
(i was driving 130mph for about 10 minutes going to NY)
can somebody tell me what it is? this hesistation?
Old Oct 1, 2001 | 04:44 PM
TheShad0w's Avatar
Default Re: VTEC, it pulls then it doesn't? whats wrong? (bommiE)
check your cam seals, and head gasket
Old Oct 1, 2001 | 05:09 PM
John's Avatar
New User
Default Re: VTEC, it pulls then it doesn't? whats wrong? (TheShad0w)
it could be a number of things:
1) check your oil level... if you're .25 qt. short, then there won't be enough oil pressure to enable VTEC
2) check your VTEC solenoid, they have been known to burn out...
3) TCR valve (i think that's what it's called)
4) sometimes a spring in the oil pump goes....
that's all i can think of right now...
Old Oct 2, 2001 | 09:55 AM
VTC_CiViC's Avatar
Default Re: VTEC, it pulls then it doesn't? whats wrong? (DunReit)
Actually you can be as much as 2+qts low on oil and VTEC will engage, found this out the hard way when I had my GS-R going around a corner with VTEC wailing, suddenly it drops off the big cam and the CE and oil light come on together! After wiping myself, I check the oil level and alas, it's not registering on the dipstick. I added 2 qts of Mobil 1 and it was back to normal on the level indicator, and both the CEL and oil lights went away, drove it for a bit and all was well. Moral of the story? Check your oil level!
Old Oct 2, 2001 | 10:41 AM
BoM's Avatar
BoM
Default Re: VTEC, it pulls then it doesn't? whats wrong? (VTC_CiViC)
VTec engages, i feel the extra pull also i hear it engage...but a little after it dies off not pulling no more...
soo oil pressure dropping when it engages could be one problem...
Old Oct 2, 2001 | 03:34 PM
lsvtec42's Avatar
New User
as far as i know oil pressure should be atleast 55 pounds(if you have an oil press. gauge)...mine dose the same thing when theres not enought oil...just my 2 cents..later
k
Old Oct 2, 2001 | 05:58 PM
blkDOHCsol's Avatar
New User
Default Re: VTEC, it pulls then it doesn't? whats wrong? (lsvtec42)
That happened to me once....check your oil..It is probably low..If not then change the oil..if the problem proceeds..kill yourself
Old Oct 2, 2001 | 05:59 PM
blkDOHCsol's Avatar
New User
tigasin
Nov 14, 2008 11:58 PM
DIYMIKE
May 30, 2004 05:29 PM
DIYMIKE
May 30, 2004 11:46 AM
spoonef
Feb 28, 2003 10:01 AM
01-1293
Oct 9, 2002 03:03 PM
