OK to Leave Car up on Jack Stands for Weeks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux »</TD></TR><TR><TD CLASS="quote">Is there any issue with leaving the car up on jack stands for a couple weeks?</TD></TR></TABLE>
I've left cars on jackstands for over a year. screw the frame.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">have someone change out the headlight blinker fluid atleast once every two weeks, or the gaskets may prematurely wear out
Don't forget the Muffler Bearing, and hyphen-doofinator.
</TD></TR></TABLE>Don't forget the Muffler Bearing, and hyphen-doofinator.
actually when you have a really old car that you want to store for winter they recommend that you put it on jack stands. so you dont **** up the tires or the suspension. so yeah id say its safe to leave it on jack stands. i had my mr2 on jack stands for a few weeks and it was fine.
edit: and dont forget to change out the radiator fluid filter. alot of people forget about it and over heat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">I heard that your ASGM can go bad if you let it sit outside for weeks in a humid climate.</TD></TR></TABLE>
nah.. that's yet more misinformation being spread on honda-tech.. you've jumped on the ASGM goes bad bandwagon I see.. I did independant testing, one car sitting outside on a dyno in humidity for weeks, and another on a dyno inside with 0 humidity.. SAE corrected dyno results were identical.. but then again, it was different cars.. maybe the ASGM on the car outside was of higher quality..
or perhaps you mean this: http://www.asgm.org.au/ Old people hate humidity..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ElKamino »</TD></TR><TR><TD CLASS="quote">
I've left cars on jackstands for over a year. screw the frame.</TD></TR></TABLE>
w3rd
w3rd
flybert
13
Nov 12, 2004 05:38 PM
