turboXS RFL bov...past 25psi?
can it handle past 25psi???on the website it says good up until 25psi...was wondering if it could handle 28 with maybe all the washers in or something?would the washers help?
Just a question about BOV's max boost ratings. Does the max number have to do more with flow or the fact that the BOV opens up at a certain pressure? My weird logic tells me that if the vacume source going to the BOV has pressure on it, then how can the pressure in the charge pipe push the BOV open? Wouldn't the pressure on both side of the piston be the same?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">also it says that one is also reccomended for 10-25psi
I ran mine at 5psi for a while and it works fine.
</TD></TR></TABLE>I ran mine at 5psi for a while and it works fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omahaturbocivic »</TD></TR><TR><TD CLASS="quote">
I ran mine at 5psi for a while and it works fine.</TD></TR></TABLE>
so did I
even 3psi, LOL
so did I
even 3psi, LOL
