Check Engine Light on 1993 si hatch (EG Civic)
check engine light comes on certain times when I start it up (and stays on) and other times it does not.. now I know that I should run the codes from the ECU, but I wondered if anyone would give me a heads up on possibilities.. many have told me the o2 senser could be goin' out..
When the light is on, nothing seems wrong with the car, not spit/sputtering, loss of power, etc.. so I'm just curious
THANX
THANX
Take a paper clip and jump the harness under the glove compartment.
It will take you more time to find the paper clip then to get the code and know exactly what is wrong
You'll have to get under the glove compartment and take a look. Right in the corner of the glove compartment closest to the door you'll see 2 harnesses that are in a rubber holder. I believe the plug is green. It's pretty small. Just plug one end of the paper clip in 1 of the holes and the other side in the number 2 hole of the harness.
and the point of jumping the harness is what? to bypass something?? or to allow it to blink a code?? (sorry I'm not real smart on the electronic end of the EG civic...
Thanx again!!!
Thanx again!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bassicfun »</TD></TR><TR><TD CLASS="quote">and the point of jumping the harness is what? to bypass something?? or to allow it to blink a code?? (sorry I'm not real smart on the electronic end of the EG civic...
Thanx again!!!</TD></TR></TABLE>
Yes, it will blink the Check Engine light to give you a code.
EFJDM1
Sep 23, 2016 10:33 PM
89civichb
May 10, 2007 06:42 PM
austincivic
Jan 29, 2007 09:10 PM
greenDC2
Feb 25, 2005 09:41 AM
thanx
