FPR question
Old Jul 28, 2003 | 04:34 PM
quik1's Avatar
Default FPR question
I purchased and installed a B&M fpr a year ago, the regulator worked fine for a while but while trying to diagnose a problem I have come to find that my B&M fpr has gone bad. When I am under full throttle and vtec kicks in I can hear it but it does'nt seem to want to pull hard, when I swap a stock fpr in it pulls hard. My question is should I just modify my last stock fpr for the B&M or do you think its the B&M part that has gone bad. I can't really see the B&M part going wrong because its just a spring but I wanted to get some opinions before I cut up my last stock FPR. Thanks ahead.
Old Jul 28, 2003 | 06:20 PM
quik1's Avatar
Default Re: FPR question (quik1)
bump
Old Jul 28, 2003 | 07:52 PM
poison's Avatar
What is your fuel PSI set at WOT and idle??
Keep us posted. I might have a suggestion for you.
Old Jul 28, 2003 | 08:27 PM
Jaesung's Avatar
i have a b&m fpr and had it for about 2years now. no problems yet. what setting did you have it on? What's your mods? did you notice that much of a difference with stock and b&m vs stock?
Old Jul 29, 2003 | 03:37 PM
quik1's Avatar
Default Re: (Jaesung)
It was working fine I took the car in to get my hondata tuned, they set it at I think about 50 psi but then I had to put a stock p30 ecu in and my fpr would not go down lower than 45 psi. So I just have the stock one in right now. There is a huge power difference when I swap the two around, the stock one being the better one.
Old Jul 29, 2003 | 04:09 PM
Jaesung's Avatar
i suggest checking your hondata wiring. it may not be that exactly but do check bc hondata messes around with fulel map no?
let me know how it goes. i may not have all the answers but i can guess....
Old Jul 29, 2003 | 06:08 PM
F1Spec's Avatar
Default Re: (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">It was working fine I took the car in to get my hondata tuned, </TD></TR></TABLE>
you do not need a b&m fpr when u have a hondata system tuned.
Old Jul 29, 2003 | 06:27 PM
quik1's Avatar
Default Re: (s2geezy)
No my hondata is not even in right now I was having problems with that too. I am just talking about the fuel pressure regulator. I know that the fpr is bad I want to know if it is the stock regulator part or the B&M part. Thanks anyways.
Old Jul 30, 2003 | 03:58 PM
quik1's Avatar
Default Re: (quik1)
Bump
j0keefe21
Oct 23, 2009 05:23 PM
schock3
23
Aug 13, 2009 09:45 AM
Mark
Sep 15, 2003 11:00 AM
Tofurky
Jul 25, 2003 11:23 PM
ceemarun
Jun 18, 2002 03:52 AM
