all motor crankshaft
Old Jul 28, 2003 | 11:39 AM
JBk24crx's Avatar
Default all motor crankshaft
what performance gains will i see from polishing the crankshaft and balancing. is knife edging realy necessary. thanks H-T all motor gurus.
Old Jul 28, 2003 | 12:28 PM
MackSpeed-616's Avatar
Default Re: all motor crankshaft (rub760)
polishing and balancing should always be considered for anytype of performance buildup...its not really too expensive either. also be sure you balance the entire rotating assembly.
knife edge is really not recommended as it can reduce the strength of the crank. and the gains are relatively minimal.
people try to argue that the crank is slowed down by the oil it dips into... when in fact, it never dips into the oil pan
Old Jul 28, 2003 | 02:36 PM
-Racer X-
Guest
Posts: n/a
Default Re: all motor crankshaft (MackSpeed-616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackSpeed-616 &raquo;</TD></TR><TR><TD CLASS="quote">polishing and balancing should always be considered for anytype of performance buildup...its not really too expensive either. also be sure you balance the entire rotating assembly.
people try to argue that the crank is slowed down by the oil it dips into... when in fact, it never dips into the oil pan</TD></TR></TABLE>
ya, knife edging is a american car thing, cause they're crank dips into the actuall oil right? i got a balanced and mirco polished crank...its weird because it dosent even feel to smooth...i thought it was supposed to be...
Old Jul 28, 2003 | 02:43 PM
Default Re: all motor crankshaft (-Racer X-)
thats b/c they only polish the journals.. not the entire crank.
Old Jul 28, 2003 | 03:08 PM
xonn's Avatar
it's actually more of an aerodynamic thing than an attempt to reduce parasitic loss
Old Jul 28, 2003 | 03:22 PM
Default Re: all motor crankshaft (xonn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xonn &raquo;</TD></TR><TR><TD CLASS="quote">it's actually more of an aerodynamic thing than an attempt to reduce parasitic loss</TD></TR></TABLE>
sure...but losing the reliability and strength of the stock crank to gain some aero dynamics is high cost.
Old Jul 28, 2003 | 03:29 PM
xonn's Avatar
I agree... which is why I haven't/wouldn't do it in a street car. In a dedicated race engine that get rebuilt every season yeah, but not in a street car.
Old Jul 28, 2003 | 04:45 PM
ENDYN's Avatar
The Old One
Domestic cranks don't dip into oil any more than Honda cranks do.
Old Jul 28, 2003 | 04:58 PM
MAX_CFM's Avatar
Default Re: all motor crankshaft (Woofer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Woofer &raquo;</TD></TR><TR><TD CLASS="quote">Domestic cranks don't dip into oil any more than Honda cranks do.</TD></TR></TABLE>
Thats what i was thinking
I recently foundsome power
with a crankshaft scraper I made
I will be selling them for $175
Old Jul 28, 2003 | 05:01 PM
so where did this myth come from that everyone talks about, how the oil slows down the crank as it cuts through it?
Old Jul 28, 2003 | 05:10 PM
hybrid_KJ's Avatar
If the crank actually was running through the oil it would foam up pretty bad I'd imagine.
Old Aug 8, 2003 | 03:28 PM
Christian's Avatar
Default Re: all motor crankshaft (hybrid_KJ)
What do you guys think of Eagle cranks? I am especially interested in comments on the Knife-Edged Eagle.
Old Aug 8, 2003 | 03:32 PM
Benny Hinn's Avatar
Default Re: all motor crankshaft (Christian)
there is a "fog" of oil in your bottom end, the crank must cut through the "fog" which can actually be quite thick.
Old Aug 9, 2003 | 06:02 AM
sikcrx80's Avatar
so the question is:
how many have it done to there crank and how many dont think to do it..
Old Aug 9, 2003 | 11:15 AM
b19coupe's Avatar
Default Re: (sikcrx80)
I always like to have my crank polished
Old Aug 9, 2003 | 11:52 AM
LSiTurbo's Avatar
Default Re: (b19coupe)
Knife egding a crank does not make the crank any weaker b/c it is taken off the counter weights.
civickid03
Mar 25, 2008 02:24 PM
civiwhip
Nov 18, 2005 10:03 AM
jmonee112
Jul 7, 2004 09:43 AM
dohc-nyne
May 5, 2003 10:25 AM
wrXtian
Mar 4, 2003 03:09 PM
