Hessitation and power loss when shifting at lower RPMS in a 1999 Civic EX
Old Jul 28, 2003 | 10:53 AM
arrland's Avatar
Default Hessitation and power loss when shifting at lower RPMS in a 1999 Civic EX
My car hesitates when shifting and has seem to have lost some pep in acceloration in lower RPM revs. My plugs are bosch plantium plus fours and are about a year old with about 20k on them. Everything else is pretty much stock. As far as the engine goes. It has about 65k miles on it. It hesitates and takes longer to get up to the higher RPM it surges slightly when shifting. Like the engine can't take the load. Any suggestions on how to regain or even increase the power with after market mods would be apperciated.
Thanks,
-Bob
Old Jul 28, 2003 | 11:20 AM
AllmotorJunkie's Avatar
Default Re: Hessitation and power loss when shifting at lower RPMS in a 1999 Civic EX (arrland)
When you say Hesitation....do you mean bogging?
Old Jul 28, 2003 | 11:51 AM
Crisgo's Avatar
I have seen and heard of problems using bosch platinum plugs in honda motors (working at a honda dealer) in most cases the techs tell me they switch them out to stock factory ngk's and that seems to fix the car to run better or in some cases just to start. Hopefully that is your problem. If not when was the last time the car has been tuned up, auto or manual tranny?
Old Jul 28, 2003 | 11:58 AM
mmuller's Avatar
Mad Scientist
Default Re: Hessitation and power loss when shifting at lower RPMS in a 1999 Civic EX (Crisgo)
like Crisgo sayd bosh platinum suck for hondas...i had the +4 and never again. put new spark plugs in, check ig. wire resistance and check cap & rotor
Old Jul 28, 2003 | 08:05 PM
b20_ed's Avatar
Default Re: Hessitation and power loss when shifting at lower RPMS in a 1999 Civic EX (mmuller)
can anybody explain why the bosch plat's suck? I have em in my car and was curious
Old Jul 28, 2003 | 08:20 PM
poison's Avatar
Default Re: Hessitation and power loss when shifting at lower RPMS in a 1999 Civic EX (b20_EK)
Check cap/rotor, and also the color of your spark plugs. Could be the spark plugs, but has to be a number of things in order to do that.
Do you have any codes?
Old Jul 29, 2003 | 05:23 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20_EK &raquo;</TD></TR><TR><TD CLASS="quote">can anybody explain why the bosch plat's suck? I have em in my car and was curious </TD></TR></TABLE>
Yeah, me too. I've used 'em in a few cars including my '95 GS-R for quite a while. They've worked really good for me.
The Saab boards are full of people who say they they suck under heavy boost. My former '89 Saab wasn't turbo & they worked fine there, too.
Old Jul 29, 2003 | 10:13 AM
Crisgo's Avatar
Default Re: Hessitation and power loss when shifting at lower RPMS in a 1999 Civic EX (JimBlake)
From what I understand the bosch platinums dont get hot enough and the spark gap is not adjustable, like factory plugs .032 recommended or so
keithcornelius
Honda Civic (2001 - 2005)
May 30, 2017 10:31 AM
Djkevinpaul
21
May 25, 2016 07:41 PM
Ruinator
12
Oct 7, 2012 04:29 PM
rdelucas1
Jul 25, 2008 02:13 PM
carlosian
Apr 20, 2007 12:06 PM
