help stuttering problem
Old Jul 28, 2003 | 04:13 AM
sohc_boy's Avatar
Default help stuttering problem
here's the prob under light acceleration my car will stutter like its going to quit but when u get into the gas it cleans up. it also does this when u hold a steady rpm like when u are cruising on the highway. the cap, rotor & wires looked ok to me and i just replaced the plugs. the car is a 99 cx and i have the normal bolt ons with a z6 intake manifold swap. it is becoming progressively worse.
Old Jul 28, 2003 | 05:55 AM
Trey's Avatar
25 Year Member
Default Re: help stuttering problem (sohc_boy)
Have you changed the plugs?
Old Jul 28, 2003 | 06:50 AM
sohc_boy's Avatar
Default Re: help stuttering problem (Trey)
yeah i just replaced them.
Old Jul 28, 2003 | 06:56 AM
ko's Avatar
ko
i have the same problem, but i have a funny feeling it has something to do with my MSD ignition haveing no external coil for it. is it possable to fry my stock one if i JUST use the MSD SCI ignition?
Old Jul 28, 2003 | 07:02 AM
opi's Avatar
opi
try changing the cap and rotor...are you running an aftermarket ignition?
Old Jul 28, 2003 | 08:10 AM
N~FaMouSKhMerBoi's Avatar
Default Re: help stuttering problem (opi)
i have the same problem...fuel filter??
Old Jul 28, 2003 | 08:24 AM
blackhatchy's Avatar
Default Re: help stuttering problem (N~FaMouSKhMerBoi)
could it be the timing?
Old Jul 28, 2003 | 08:55 AM
sohc_boy's Avatar
Default Re: help stuttering problem (blackhatchy)
timing is stock and i already ripped the msd out thinking it was that. cap and rotor look ok, but i'm gonna change them tonite to see if it helps. i haven't chk'd the fuel filter yet, if it still doing it after i change the cap and rotor than i will prolly look at that next.
Old Jul 28, 2003 | 09:18 AM
ko's Avatar
ko
time out, did you have just the ignition on there??? no external coil /blaster pack or anything like that???
cuz we both seem to be having the same problem and just so happened to have the same parts.
Old Jul 28, 2003 | 10:01 AM
sohc_boy's Avatar
Default Re: help stuttering problem (DOHC hatch ej)
no external coil, everything on the ignition is/was stock except for an msd box. i removed that thinking it might have been the problem but it still does the same thing.
Old Jul 28, 2003 | 11:14 AM
d_mina's Avatar
try changing the whole cap and rotor assembly...i just did that yesterday to my h22 and it fixed it...feels alot smoother now too...my problem was pretty obvious tho because i had a lil oil in my cap
Old Jul 28, 2003 | 04:24 PM
Default Re: (teameracer3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teameracer3 &raquo;</TD></TR><TR><TD CLASS="quote">try changing the whole cap and rotor assembly...i just did that yesterday to my h22 and it fixed it...feels alot smoother now too...my problem was pretty obvious tho because i had a lil oil in my cap</TD></TR></TABLE>
how much did that run you $$??
would it cost the same for a civic..and where did you get your stuff
Old Jul 29, 2003 | 04:24 AM
sohc_boy's Avatar
Default Re: (N~FaMouSKhMerBoi)
just changed the cap and rotor, still doing it. the cap and rotor cost 26 dollars from advance. man i'm really getting annoyed that its still doing it i guess i'll try the fuel filter next.
mightyjoecivic
11
Jul 13, 2022 08:04 PM
THC07
11
Nov 10, 2005 09:27 PM
slooogsr
Jul 5, 2003 08:55 PM
loki2323
Jun 11, 2002 02:42 PM
carcala
Jun 6, 2002 09:53 PM
