LS distributer on Vtec head
Old Jul 27, 2003 | 05:12 PM
b20mike's Avatar
Default LS distributer on Vtec head
I have searched alot on how to do this and apparently it is possible but I am not sure exactly how to do it and maintain 2 bolts holding it on. does anyone have a detailed explanation on how to do this or even possibly a picture.
Thanks, Mike.
Old Jul 27, 2003 | 09:11 PM
salbaje's Avatar
Default Re: LS distributer on Vtec head (b20mike)
i think only 1 bolt will work. but if you align another bolt that's great you'll need to either cut one of the legs to make it work
Old Jul 27, 2003 | 10:29 PM
DOHCtorTHRUST's Avatar
Default Re: LS distributer on Vtec head (salbaje)
two of the three will line up and bolt on if i remember correctly... face the dist upward like its suppose too and you'll notice that one leg is not lining up, cut that one and you'll be fine
Old Jul 28, 2003 | 03:33 AM
krazyDOHC's Avatar
Default Re: LS distributer on Vtec head (DOHCtorTHRUST)
only 1 bolt lined up(top one of course)....and we had to cut one of the legs in order for it to fit
Old Jul 28, 2003 | 03:10 PM
b20mike's Avatar
Default Re: LS distributer on Vtec head (krazySOHC)
Yeah I am having the same problem
only one bolt is lining up.
Another question I have is if a OBD2 distributer is the same internally as OBD1 in other words if I re wire the clip to fit can I use an OBD2 distributer with an OBD1 ECU?
Old Jul 28, 2003 | 03:12 PM
thid92's Avatar
can I haz?
bump
Old Jul 28, 2003 | 10:27 PM
salbaje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20mike &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I am having the same problem
Another question I have is if a OBD2 distributer is the same internally as OBD1 in other words if I re wire the clip to fit can I use an OBD2 distributer with an OBD1 ECU?</TD></TR></TABLE>
damn looks like you are reclipping your parts to fit obd1.
Jimmy
Nov 4, 2008 01:32 PM
BlakeJ53
Apr 26, 2008 09:53 PM
GimpyVtec
Sep 7, 2007 03:34 PM
Btothe3rdDegree
20
Jan 23, 2005 01:36 PM
