Stripped bolt in head..
Old Nov 4, 2008 | 12:15 AM
Jimmy's Avatar
Global Moderator
Default Stripped bolt in head..
http://www.acuraautomotivepart...ormal
#5 on the diagram is stripped.. the bolt keeps coming loose. which results in the engine ticking..
How can i fix this? The bolt is like a banjo bolt (hole in the middle) so if i repair the threads.. i would need a bigger bolt.. and where could i find a bigger bolt that type to fit?
Anyone else ever had this happen?
Any input is needed..!
Old Nov 4, 2008 | 07:17 AM
HitF8's Avatar
Default Re: Stripped bolt in head.. (Jimmy)
your best bet would probablly be to take it to a machine shop. see what they say good luck
Old Nov 4, 2008 | 08:57 AM
Jimmy's Avatar
Global Moderator
I will consider.. ttt bump!
Old Nov 4, 2008 | 01:32 PM
DonF's Avatar
Default Re: (Jimmy)
I really doubt you are going to fix this, LS heads are cheap, probably less than the repair.
87CRX
Aug 30, 2008 05:59 AM
HCivicSi23
Jul 14, 2007 11:15 PM
spidermancivic
Oct 5, 2006 10:10 PM
spidermancivic
Oct 3, 2006 09:41 PM
greyzone
Audio / Security / Video
10
Jan 5, 2003 08:51 PM
