LS distributer on Vtec head
I have searched alot on how to do this and apparently it is possible but I am not sure exactly how to do it and maintain 2 bolts holding it on. does anyone have a detailed explanation on how to do this or even possibly a picture.
Thanks, Mike.
Thanks, Mike.
Re: LS distributer on Vtec head (b20mike)
i think only 1 bolt will work. but if you align another bolt that's great you'll need to either cut one of the legs to make it work
Re: LS distributer on Vtec head (salbaje)
two of the three will line up and bolt on if i remember correctly... face the dist upward like its suppose too and you'll notice that one leg is not lining up, cut that one and you'll be fine
Re: LS distributer on Vtec head (krazySOHC)
Yeah I am having the same problem
only one bolt is lining up.
Another question I have is if a OBD2 distributer is the same internally as OBD1 in other words if I re wire the clip to fit can I use an OBD2 distributer with an OBD1 ECU?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20mike »</TD></TR><TR><TD CLASS="quote">Yeah I am having the same problem
Another question I have is if a OBD2 distributer is the same internally as OBD1 in other words if I re wire the clip to fit can I use an OBD2 distributer with an OBD1 ECU?</TD></TR></TABLE>
damn looks like you are reclipping your parts to fit obd1.
BlakeJ53
04-26-2008 09:53 PM
Btothe3rdDegree
20
01-23-2005 01:36 PM
