What pistons and rods to put into an ls/vtec
I have been searching for awhile, but i just want to know what would the best pistons and rods to throw into my b18b/gsr head hybrid. I plan on staying NA, and later dropping in some toda b cams. basically i want to strengthen my bottom end, i am already looking at eagle rods, but notsure on the pistons. any ideas, of input would be greatly appreciated.
-JDM ITR Pistons
-Shot Peened Rods (LS)
-ARP Rod Bolts + Head Studs
= 11.36 CR with OEM Head Gasket
~ 11.67 CR with 2 Layer Gasket
..where have you been searching..?
if you want more compression go with the JDM B16 (P30) Pistons.
= 11.59 CR with OEM HG
~ 11.92 CR with 2 Layer
Please dont go CTR pistons with you GSR head...
Whats the highest Pump Gas that you can get in your area?
yeah gsr head that was milled, .. after the jackass before me overheated and warped it. thanks for the help...so no ctr pistons oh and btw 93 octane down here in daytona
over heated..that sucks..!
if you wanna go with an After Market Rod on OEM Pistons then check this out..
http://ef-1.zeroforum.com/zerothread?id=7
But a Shot Peened LS Rod would/should hold up fine...
http://www.SummitRacing.com has the best prices that ive seen for the ARP stuff...
skoodles2k6
Sep 18, 2007 09:27 PM
