CEL with no code!!!!
Old Jul 27, 2003 | 10:22 AM
CiViC SiR's Avatar
Default CEL with no code!!!!
my check engine light is on but there is no code ????
what shall i do?
Old Jul 27, 2003 | 10:34 AM
st00pid's Avatar
Default Re: CEL with no code!!!! (CiViC SiR)
Sounds like a problem with teh ECU, replace and check. I have also found that pinched or shorted injector or O2 wires also cause problems.
Old Jul 27, 2003 | 10:42 AM
vtec.dc2's Avatar
any modifications done to ecu?
Old Jul 27, 2003 | 11:41 AM
CiViC SiR's Avatar
Default Re: CEL with no code!!!! (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">any modifications done to ecu?</TD></TR></TABLE>
yes
turbo upgrade with 3 bar map
Old Jul 27, 2003 | 01:46 PM
scttydb411's Avatar
if you have jumped the service connector and it doesn't blink it is just a random misfire. happened to me right after i installed safc before going turbo. reset it and see if it comes back on. make sure you jump the connector to read the code though.
Old Jul 27, 2003 | 04:38 PM
Hondata's Avatar
You mention 3 bar map. If you are running a Hondata ECU with a P28 and have the knock sensor enabled you wiull get a CEL with no code.
Geis
Dec 17, 2015 11:20 AM
msinsky14
Jan 6, 2009 07:44 PM
bmoua
Dec 29, 2007 09:08 PM
billyhoe
Oct 17, 2004 08:58 AM
KiD Fr0m Da 516
Aug 2, 2004 06:36 AM
